Full Version: Series programming via epg - How?
A little question from my side and i hope someone here can help me:
I want to add a episode programming through the epg but kodi just says: Feature not supported from the pvr plugin.
Do i something wrong or how do you program series via epg?
(i know that the programming can be done via webinterface and autosearch, but i wanted to do it from inside kodi)
Thats only possible using the webinterface. RS/DMS has no API for EPG based timers, only an internal one the webinterface is using.
Ok, thank you for this fast feedback!
