Full Version: Unexpected behavior from xbmc.monitor()
I've been encountering unexpected behavior from xbmc.monitor.waitForAbort, Everytime either a single video or the first playlist entry ends the loop breaks.
I thought I was tracking a bug within xbmc.monitor(), but from what I can tell from the source this is a design feature?
https://github.com/xbmc/xbmc/blob/72d0c2...onitor.cpp
Endtime thread from player is included as abortEvent? am I correctly reading the source? I wonder what would be the appropriate solution (workaround) for my situation?
I'd like to have a loop running a function while a short video is playing... Would it be okay to use
while True:
and create my own break code since I can abort the loop based on the window status?
Example pseudo code below, thanks for any help.
SHORTCLIP = 20SECCLIP
class Screensaver(xbmcgui.WindowXMLDialog):
    def __init__(self, *args, **kwargs ):
        playlist = xbmc.PlayList(xbmc.PLAYLIST_VIDEO)
        playlist.clear()
        for i in range(30):
            playlist.add(SHORTCLIP)
        xbmc.executebuiltin("PlayerControl(RepeatAll)")
        xbmc.Player().play(playlist)
    def onInit(self):
        self.start()
    def start(self):
        while not xbmc.Monitor().abortRequested():
            doSomething()
            if xbmc.Monitor().waitForAbort(30) == True:
                break
        self.closeWindow()
    def onAction(self, action):
        self.closeWindow()
    def closeWindow(self):
        xbmc.Player().stop()
        xbmc.executebuiltin("PlayerControl(RepeatOff)")
        self.close()
@Lunatixz
Quote:I thought I was tracking a bug within xbmc.monitor(), but from what I can tell from the source this is a design feature?
I'm not a C++ expert but I don't see anything player-related in the code. It looks like a homegrown solution similar to std::chrono, but, as I understand, most of Kodi codebase predates C++11, hence many homegrown solutions instead of modern std:: features.
If the bug indeed occurs and reproducible, I guess you need to submit a bug report.
Yes that link doesn't but following the includes they lead to the XBMC.thread, system time and player both using a class called Endtime. I'm rusty with C, so I could be mistaken.
I'll open a ticket since at least for me it's reproducible.
Sent from my SM-G935T
