Full Version: Horizon - Krypton
Horizon
Proud to announce the beta release of Horizon, a skin for Kodi Krypton 17 by jurialmunkey and Swageroni_
Everything should work properly. However, this is a beta release so expect bugs and also changes as skin development progresses.
Please report any bugs you encounter.
Enjoy! Big Grin
Github Download
https://github.com/jurialmunkey/skin.horizon
Instructions: Follow the github link above to go to the github page. Click the green "Clone or Download" button. Select download zip. Github updates need to be done manually, so when updating the skin make sure you give the zip file a unique name otherwise kodi will try to use a cached version (I usually just add the date on the end - e.g. skin.horizon-180717.zip). Then go to Add-ons and select install from zip (you might need to turn on install from unknown sources in System Settings > Add-ons).
Horizon genre icon pack by Swageroni_
https://github.com/Swageroni/resource.im...ns.horizon
Disclaimer
The skin is for KRYPTON ONLY. However, many users have reported that the skin works well on Leia also. The main change needed is an updated DialogAddonSettings.xml which bsoriano has kindly made the changes for and provided in this post:
https://forum.kodi.tv/showthread.php?tid...pid2614171
Dependencies
kodi.krypton
script.skinshortcuts
script.skin.helper.service
script.extendedinfo
script.image.resource.select
plugin.program.autocompletion
resource.image.studios.white
resource.image.moviegenreicons.transparent
Creative Commons BY-NC-SA 4.0
realjohngalt for the inspiration of the list view and video info layout.
marcelveldt and bobcratchet for skinhelper and skinshortcuts - the duo of addons no skin should be without!
manfeed for video lyrics which are just awesome
nessus for bello which provided the music overlay colours and music osd scrolling text idea
meridius for touching up some of the source flags
and, of course, Swageroni_ who without his mockups this skin would not be possible!
If I've missed someone let me know and I'll put you here.
Images
watch gallery
jurialmunkey
looking so good ....
Will this be its own skin or a view option of (fuse) neue ??
Yeah it will be its own skin. I originally was going to make it an option, but very early on I realised that there were just far too many changes and it was going to be too complicated.
Very Nice. Reminds me a liiiittle bit of Eminence on that list view.
edit: love those textures too, especially on the big top bar and thee way it contrasts straight underneath with the light line. Material-ish
Ok great .... will you be adding this view inspired by Horizon ?
https://forum.kodi.tv/showthread.php?tid...pid2517813
this is what i want a look for Fuse skin
stunning look
(2017-06-28, 13:27)Silki Wrote: [ -> ]Ok great .... will you be adding this view inspired by Horizon ?
Beautiful!
This looks epic! I was a huge fan of horizon but saw the dev stopped logging in as well and was quite disapointed
Not sure if its in the cards but a huge preference of mine is having different view options for widgets i.e. Posters, Landscape, banners and more......
That would be my vote to set this skin apart and make it out of this world.
And that Horizon view is also pretty awesome if it can be incorporated
This looks great. I can't wait to try it out.
I hope you will keep the same music player that is in (fuse)neue, with the color overlay and scrolling text. That's the best!
(2017-06-28, 13:21)mark2112 Wrote: [ -> ]Very Nice. Reminds me a liiiittle bit of Eminence on that list view.
Thanks Smile
Possibly. I'm focusing on getting everything else working first (e.g. all the dialogs and so on) before I start adding view types, but definitely is a possibility.
(2017-06-29, 10:39)pauly3069 Wrote: [ -> ]This looks epic! I was a huge fan of horizon but saw the dev stopped logging in as well and was quite disapointed
Currently the widgets automatically determine whether to show posters or square, but I will probably also add a landscape toggle.
(2017-06-29, 20:22)sepp650 Wrote: [ -> ]This looks great. I can't wait to try it out.
Yep the music and video player/osd will be staying the same.
Nice!!!
Will this skin have animated posters ?@jurialmonkey
I like the skin very much but when I enable the rss feed not seein anything please help
Fuse horizon isn't available yet..i think you need to ask that question on the other thread
(2017-07-03, 02:55)Jay19802005 Wrote: [ -> ]Will this skin have animated posters ?@jurialmonkey
Yep already supports them because I re-used the image variables from (fuse)neue.
