Hello friends !!!!
Kodi is crashing on me on start up and also once it gets past 1st run , when I try to install a source (unknown sources are off) from Kodi repo. This all coincided with a windows update. I even rolled back the update and have the same results.
I enabled debugging and went through a crash. Attached are the logs.
Kodi Text Doc
https://pastebin.com/eZF34f1P
Can't open DMP file so used zippy
kodi_crashlog-17.3 Git_20170524-147cec4-20170628-121705.dmp
http://www45.zippyshare.com/v/dkQGvWTT/file.html
EDIT _ This also happens on portable and also a 17.3 fork as well.
I can do some things with the computer....... Can you walk me thru it?
Not sure where to rename it and how....
12:15:51.633 T:23592 INFO: ADDON: cpluff: 'Could not read plug-in directory C:\Users\matt\AppData\Roaming\Kodi\addons: No such file or directory'
This suggests that either the addons folder doesn't exist, or the user account you're running kodi as does not have permission to access it.
Does the folder "C:\Users\matt\AppData\Roaming\Kodi\addons" exist?
If not, create it and try again.
If it does exist, check its security settings. Does your user account have permission to access it (should be full control)? If not, grant permissions and try again.
Sir the folder exists and I checked properties on the %appdata% Kodi folder. It has full permisiions.
I'd gladly pass along team view digits to an admin. In box me.
Hello Mattmaier1975
What is it that you want to pass onto an admin?
Team Viewer #'s for remote help! if possible...
Mostly , the silvo skin to play around with. You tube for videos , world star hip hop for laughs.
Sorry, we do not offer remote or private assistance.
All questions and answers are posted here on the forum so they are available for all to read and assist with. This also allows others suffering similar problems to find solutions.
Ok, anything else I can provide so i can resolve this issue?
As well as enabling debug, could you also enable curl logging? And then restart kodi and try to install just one addon.
Then post your log to pastebin again, and tell us which addon you tried to install.
(2017-06-30, 18:33)mrm518 Wrote: [ -> ]just re downloaded 17.3 version and its crashing when files are updating. has been going on for awhile
https://pastebin.com/uS2p547u
Not a full debug log:
12:03:27.963 T:11248 NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:03:27.963 T:11248 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
Enable debug log in kodi settings, restart kodi and trigger the crash
