Quote:Basically you need a plain text file containing the filenames (and paths?) of anything you've watched so you can feed that list into another program to move those files somewhere else.
Yes, sorry, forgot to mention this. And yes, the file / movie name would be enough to enter it in the / a sync program to be included (and exclude all of the other files / folders).
Quote:Ie. Foreach (filename in filenamelist) { move file }
Is that right?
Yes, it looks right, each watched movie (usually in a single movie folder) with files / folders (.actors and such) belonging to the movie file shall be moved to an external drive.
Quote: There may be a niche addon somewhere that will do the job, but you might need to code something yourself. Either a kodi addon or just a script that will query the kodi database and dump the info you need.
Yes, if only I were able to code. I am happy to be able of copying / moving files.
Quote:For example using database MyVideos107.db, this query...
SELECT path.strPath, files.strFilename FROM files, path WHERE files.idPath = path.idPath AND files.playcount > 1
Thank you. Sorry, but I do not even have any idea where to enter this.
Quote: You'd probably want to expand on that so that it only shows files found in a specific location etc.
Yes, that would be still more useful.
Quote:FYI I used the free app "DB Browser for SQLite" to run this query, then just export results to a CSV file.
So I have to do such a query somewhere here, I assume:
Quote:The output ends up as FILEPATH\FILENAME in a single field, so export is then very simple.
Thank you, I would try it.
Quote:After a little research I came across an addon in the kodi repo called "janitor" which is designed to automate the entire process and has a bunch of options which look pretty useful.
That sounds great, thank you for searching.
Quote:It doesn't export anything, but it can move files to wherever you specify based on watched status, so if that's all you want, you won't need to export.
Yes, it actually is. Additionally I want to check (by content or checksum) whether the (movie) files are transferred correctly, so I would have to copy first and after checking remove the source files.
Quote: Note that the addon description says it will "delete" the files, but you can choose between deletion and moving them to another location.
Hope, I can also choose to copy them.
Quote: It's in the programs section of the repo if you want to check it out.
Yes, of course.
Quote: The only thing I can't tell is what would happen if the destination folder was part of the kodi library. I'd hope it would ignore them.
That is indeed the case, all of the movies / series are transferred to a folder contained in the Kodi database / library.
I didn't dare to try, I assume, I can mess up the database doing a wrong query, this looks quite good to do such a query:
But I tried using a copy of that database, I have any idea where to insert that query.
Actually using a database program to export such lists does not seem to be bad respectively not bader than using Janitor or such. I could - I assume - create a shortcut, link to that query and easily start it each time I want. And there are much more options / ways, I guess, to use such a database program if / when need be, can extent queries, use for different tasks.
Thank you very much
