nickr this is fine, it is a discussion related to testing a current PR
(2017-07-05, 23:42)scott967 Wrote: [ -> ]I scanned my library in both Kodi 18 0629 nightly and the music test build, then compared MyMusic65.db to MyMusic66.db. I first scanned the whole library, then did a get info for all albums. I have local nfos for all albums so maybe I need to rerun without nfos to really test? The two databases seem identical.
I don't have any release group tags set. Is there an easy way to get the release group ids into tags or my nfos?. It should be trivial given a release id I would think.
Thanks for trying the test build Scott, and yes, on thinking about it, your NFO files will have an impact:
To populate the Musicbrainz release group id in the db you need to either
a) scan them from music files, assuming that your music is tagged with them, by either starting with a clean library, adding a new music source, or doing a forced re-scan.
Note: to trigger a forced re-scan (so useful when testing) add <promptfulltagscan>true</promptfulltagscan> to the <musiclibrary> section of advancedsettings.xml and "scan to library" from file mode context menu will prompt asking it you want to re-scan those files that are unchanged.
b) Scrape albums online (no NFOs) and they will be fetched from Musicbrainz, for those albums that are found in the Musicbrainz database. This needs lastscraped to be null, so either needs newly added/scanned music or some manual editing of the db (I know you are familiar with that Scott). A re-scraping option is something I hope to add in v18!
c) Add the <musicbrainzreleasegroupid> tag to your album.nfo files
But I have not considered providing a way for users like yourself with existing (carefully edited) NFO files to do c). Rescanning will get it from tags, then scraping the exitsing NFOs will collect your other album data. Then exporting to replace the NFO should put the release group ids in there. But I need to test that or perhaps you can, more likely to find issues than me
Thanks for bringing this up, at very least I need to add some things to the user advice.
Did you notice that scraping music with mbids
and complete NFO files is quicker? Previously the scraper waited 2s when it saw the mbid even though it then just picks up the NFO file and does not fetch anything from Musicbrainz, the throttling fix solved this.
