2017-07-06, 17:36
Hello !
First of all, my setup is composed of an Nvidia Shield (2015) and an Onkyo TX-NR656 A/V received, with 5.1.2 speakers. Kodi passthrough is enabled, and my receiver gets an Atmos signal \o/
When I play the Dolby 5.1.2 test tones file (https://www.dolby.com/us/en/guide/test-tones.html), all channels are ok. But when I play, for example, this demo (https://www.demolandia.net/downloads.php?id=438882), sometimes the channels are completly messed up.
When it's ok, I can hear the guy talking in the center speaker. But when the bug occurs, I hear him in random speakers (back left, then top right...).
This doesn't happen when playing these videos with Plex.
I join my kodi log (FYI the last play of the video was buggy).
Could someone please help me ?
Thank you !
Thank you !
17:19:39.446 T:137670939728 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:19:39.446 T:137670939728 NOTICE: -----------------------------------------------------------------------
17:19:39.446 T:137670939728 NOTICE: Starting Kodi (17.3 Git:20170524-7757567). Platform: Android ARM 64-bit
17:19:39.446 T:137670939728 NOTICE: Using Release Kodi x64 build
17:19:39.446 T:137670939728 NOTICE: Kodi compiled May 24 2017 by GCC 4.9.0 for Android ARM 64-bit API level 21 (API level 21)
17:19:39.447 T:137670939728 NOTICE: Running on NVIDIA SHIELD Android TV with Android 7.0.0 API level 24, kernel: Linux ARM 64-bit version 3.10.96+
17:19:39.447 T:137670939728 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
17:19:39.447 T:137670939728 NOTICE: 4 CPU cores available
17:19:39.447 T:137670939728 NOTICE: Product: foster_e, Device: foster, Board: unknown - Manufacturer: NVIDIA, Brand: NVIDIA, Model: SHIELD Android TV, Hardware: foster_e
17:19:39.449 T:137670939728 NOTICE: External storage path = /storage/emulated/0; status = ok
17:19:39.449 T:137670939728 NOTICE: ARM Features: Neon disabled
17:19:39.450 T:137670939728 NOTICE: special://xbmc/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
17:19:39.450 T:137670939728 NOTICE: special://xbmcbin/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
17:19:39.450 T:137670939728 NOTICE: special://xbmcbinaddons/ is mapped to: /data/app/org.xbmc.kodi-2/lib/arm64
17:19:39.450 T:137670939728 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
17:19:39.450 T:137670939728 NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
17:19:39.450 T:137670939728 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
17:19:39.450 T:137670939728 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
17:19:39.450 T:137670939728 NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
17:19:39.450 T:137670939728 NOTICE: The executable running is: /data/app/org.xbmc.kodi-2/lib/arm64/libkodi.so
17:19:39.450 T:137670939728 NOTICE: Local hostname: localhost
17:19:39.450 T:137670939728 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp//kodi.log
17:19:39.450 T:137670939728 NOTICE: -----------------------------------------------------------------------
17:19:39.451 T:137670939728 NOTICE: load settings...
17:19:39.466 T:137670939728 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
17:19:39.467 T:137670939728 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
17:19:39.480 T:137670939728 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
17:19:39.481 T:137670939728 DEBUG: Firmware implements AC3 RAW
17:19:39.481 T:137670939728 DEBUG: Firmware implements EAC3 RAW
17:19:39.481 T:137670939728 DEBUG: Firmware implements DTS RAW
17:19:39.482 T:137670939728 DEBUG: AESinkAUDIOTRACK - 32000 supported
17:19:39.482 T:137670939728 DEBUG: AESinkAUDIOTRACK - 44100 supported
17:19:39.483 T:137670939728 DEBUG: AESinkAUDIOTRACK - 48000 supported
17:19:39.483 T:137670939728 DEBUG: AESinkAUDIOTRACK - 88200 supported
17:19:39.483 T:137670939728 DEBUG: AESinkAUDIOTRACK - 96000 supported
17:19:39.484 T:137670939728 DEBUG: AESinkAUDIOTRACK - 176400 supported
17:19:39.484 T:137670939728 DEBUG: AESinkAUDIOTRACK - 192000 supported
17:19:39.485 T:137670939728 DEBUG: Firmware implements DTS-HD RAW
17:19:39.485 T:137670939728 DEBUG: Firmware implements TrueHD RAW
17:19:39.485 T:137670939728 DEBUG: AESinkAUDIOTrack: Using IEC PT mode: 13
17:19:39.485 T:137670939728 DEBUG: 8 Channel PT via IEC61937 is supported
17:19:39.485 T:137670939728 NOTICE: Found 1 Lists of Devices
17:19:39.485 T:137670939728 NOTICE: Enumerated AUDIOTRACK devices:
17:19:39.485 T:137670939728 NOTICE: Device 1
17:19:39.485 T:137670939728 NOTICE: m_deviceName : AudioTrack
17:19:39.485 T:137670939728 NOTICE: m_displayName : android
17:19:39.485 T:137670939728 NOTICE: m_displayNameExtra: audiotrack
17:19:39.485 T:137670939728 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
17:19:39.485 T:137670939728 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
17:19:39.485 T:137670939728 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
17:19:39.485 T:137670939728 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_RAW,AE_FMT_RAW
17:19:39.486 T:137670939728 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD,STREAM_TYPE_TRUEHD
17:19:39.493 T:137670939728 DEBUG: CSkinSettings: no <skinsettings> tag found
17:19:39.494 T:137670939728 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
17:19:39.495 T:137670939728 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
17:19:39.495 T:137670939728 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.2.3</host>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
<cache>
<buffermode>1</buffermode>
</cache>
</advancedsettings>
17:19:39.495 T:137670939728 WARNING: VIDEO database configuration is experimental.
17:19:39.495 T:137670939728 NOTICE: Default Video Player: VideoPlayer
17:19:39.495 T:137670939728 NOTICE: Default Audio Player: paplayer
17:19:39.495 T:137670939728 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:19:39.495 T:137670939728 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:19:39.498 T:137670939728 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:19:39.499 T:137670939728 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:19:39.519 T:137670939728 NOTICE: Loaded playercorefactory configuration
17:19:39.519 T:137670939728 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:19:39.519 T:137670939728 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:19:39.552 T:137670939728 NOTICE: Running database version Addons27
17:19:39.723 T:137670939728 NOTICE: ADDONS: Using repository repository.xbmc.org
17:19:39.754 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:19:39.758 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:19:39.782 T:137670939728 NOTICE: InitWindowSystem: Using EGL Implementation: android
17:19:39.808 T:137670939728 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
17:19:39.808 T:137670939728 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 50.000000 Hz
17:19:39.808 T:137670939728 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
17:19:39.808 T:137670939728 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 60.000000 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940060 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 59.940060 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 24.000000 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 25.000000 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 30.000000 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 23.976025 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970030 Hz
17:19:39.809 T:137670939728 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 29.970030 Hz
17:19:39.809 T:137670939728 NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
17:19:39.809 T:137670939728 NOTICE: Checking resolution 17
17:19:39.875 T:137670939728 NOTICE: GL_VENDOR = NVIDIA Corporation
17:19:39.875 T:137670939728 NOTICE: GL_RENDERER = NVIDIA Tegra
17:19:39.875 T:137670939728 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
17:19:39.875 T:137670939728 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
17:19:39.876 T:137670939728 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_clip_cull_distance GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_protected_textures GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_group_vote GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_non_constant_global_initializers GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_draw_transform_feedback GL_EXT_unpack_subimage GL_EXT_window_rectangles GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_barrier GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_OES_viewport_array GL_ANDROID_extension_pack_es31a
17:19:40.498 T:137670939728 WARNING: CAndroidJoystickState: ignoring unknown axis 32 on input device "Harmony Keyboard" with ID 3
17:19:40.498 T:137670939728 WARNING: CAndroidJoystickState: ignoring unknown axis 33 on input device "Harmony Keyboard" with ID 3
17:19:40.498 T:137670939728 WARNING: CAndroidJoystickState: ignoring unknown axis 34 on input device "Harmony Keyboard" with ID 3
17:19:40.498 T:137670939728 WARNING: CAndroidJoystickState: ignoring unknown axis 35 on input device "Harmony Keyboard" with ID 3
17:19:40.499 T:137670939728 WARNING: CAndroidJoystickState: ignoring unknown axis 36 on input device "Harmony Keyboard" with ID 3
17:19:40.783 T:137670939728 NOTICE: Register - new joystick device registered on android->android/inputdevice/3: Harmony Keyboard (FFFF:0000)
17:19:40.803 T:138053473360 NOTICE: Running database version Addons27
17:19:40.805 T:138053473360 NOTICE: Running database version ViewModes6
17:19:40.807 T:138053473360 NOTICE: Running database version Textures13
17:19:40.860 T:138053473360 NOTICE: Running database version MyMusic60
17:19:40.873 T:138053473360 NOTICE: Running database version MyVideos107
17:19:40.881 T:138053473360 NOTICE: Running database version TV29
17:19:40.884 T:138053473360 NOTICE: Running database version Epg11
17:19:41.233 T:137670939728 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:19:41.463 T:137670939728 NOTICE: UpdateLibraries: Starting video library startup scan
17:19:41.463 T:137670939728 NOTICE: UpdateLibraries: Starting music library startup scan
17:19:41.527 T:137670939728 NOTICE: initialize done
17:19:41.527 T:137670939728 NOTICE: Running the application...
17:19:41.528 T:137670939728 NOTICE: starting upnp client
17:19:41.531 T:137670939728 NOTICE: GL_VENDOR = NVIDIA Corporation
17:19:41.531 T:137670939728 NOTICE: GL_RENDERER = NVIDIA Tegra
17:19:41.531 T:137670939728 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
17:19:41.531 T:137670939728 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
17:19:41.531 T:137670939728 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_clip_cull_distance GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_protected_textures GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_group_vote GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_non_constant_global_initializers GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_draw_transform_feedback GL_EXT_unpack_subimage GL_EXT_window_rectangles GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_barrier GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_OES_viewport_array GL_ANDROID_extension_pack_es31a
17:19:41.533 T:138117833808 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
17:19:41.538 T:138147738704 NOTICE: ES: Starting UDP Event server on port 9777
17:19:41.540 T:138147738704 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
17:19:41.807 T:137670939728 NOTICE: GL_VENDOR = NVIDIA Corporation
17:19:41.809 T:137670939728 NOTICE: GL_RENDERER = NVIDIA Tegra
17:19:41.809 T:137670939728 NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 361.00
17:19:41.809 T:137670939728 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
17:19:41.810 T:137670939728 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_clip_cull_distance GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_protected_textures GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_group_vote GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_non_constant_global_initializers GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_draw_transform_feedback GL_EXT_unpack_subimage GL_EXT_window_rectangles GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_barrier GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_OES_viewport_array GL_ANDROID_extension_pack_es31a
17:19:41.829 T:137463655064 WARNING: CPeripheralBusAndroid: failed to update input device with ID -3 because it couldn't be found
17:19:42.510 T:138136241232 NOTICE: [plugin.video.youtube] Startup: detected Krypton (Kodi-17.3), setting DASH_SUPPORT_BUILTIN = False, DASH_SUPPORT_ADDON = True
17:19:43.498 T:138116797520 NOTICE: VideoInfoScanner: Starting scan ..
17:19:43.709 T:138053473360 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/Sky Atlantic (IT).png
17:19:43.719 T:138053473360 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/TVA.png
17:19:44.801 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:19:44.805 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:19:47.842 T:138115761232 ERROR: GetDirectory - Error getting
17:19:49.754 T:138115761232 ERROR: Previous line repeats 6 times.
17:19:49.755 T:138115761232 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:19:52.589 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-atmos_amaze.mp4
17:19:52.589 T:137670939728 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
17:19:52.591 T:138104783952 NOTICE: Creating InputStream
17:19:52.619 T:138104783952 NOTICE: Creating Demuxer
17:19:52.733 T:138104783952 NOTICE: Opening stream: 0 source: 256
17:19:52.733 T:138104783952 NOTICE: Creating video codec with codec id: 28
17:19:52.841 T:138104783952 NOTICE: Creating video thread
17:19:52.841 T:138104783952 NOTICE: Opening stream: 1 source: 256
17:19:52.841 T:138104783952 NOTICE: Finding audio codec for: 86057
17:19:52.841 T:138118329424 NOTICE: running thread: video_thread
17:19:52.842 T:138104783952 NOTICE: Creating audio thread
17:19:52.848 T:138136241232 NOTICE: running thread: CVideoPlayerAudio::Process()
17:19:52.849 T:138136241232 NOTICE: Creating audio stream (codec id: 86057, channels: 6, sample rate: 48000, pass-through)
17:19:52.867 T:138055545936 NOTICE: Trying to open: 192000 samplerate 12 channelMask 13 encoding
17:19:52.879 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_EAC3 min_buffer_size: 65600 m_frames: 8200 m_frameSize: 4 channels: 2
17:19:53.018 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:19:53.027 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:19:53.027 T:137670939728 NOTICE: GL: NPOT texture support detected
17:19:53.043 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:19:53.189 T:137670939728 NOTICE: VideoPlayer: OnLostDisplay received
17:19:54.866 T:138136241232 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
17:19:56.070 T:137670939728 NOTICE: VideoPlayer: OnResetDisplay received
17:19:56.070 T:138055545936 NOTICE: Trying to open: 192000 samplerate 12 channelMask 13 encoding
17:19:56.083 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_EAC3 min_buffer_size: 65600 m_frames: 8200 m_frameSize: 4 channels: 2
17:20:03.795 T:138116797520 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:20
17:20:28.471 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:20:28.471 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:20:28.479 T:138104783952 NOTICE: CVideoPlayer::OnExit()
17:20:28.479 T:138104783952 NOTICE: Closing stream player 1
17:20:28.480 T:138104783952 NOTICE: Waiting for audio thread to exit
17:20:28.485 T:138136241232 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:20:28.485 T:138104783952 NOTICE: Closing audio device
17:20:28.495 T:138104783952 NOTICE: Deleting audio codec
17:20:28.495 T:138104783952 NOTICE: Closing stream player 2
17:20:28.495 T:138104783952 NOTICE: waiting for video thread to exit
17:20:28.497 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:20:28.500 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:20:28.514 T:138118329424 NOTICE: thread end: video_thread
17:20:28.515 T:138104783952 NOTICE: deleting video codec
17:20:28.564 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:20:28.565 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-atmos_amaze.mp4
17:20:28.566 T:138105820240 NOTICE: Creating InputStream
17:20:28.611 T:138105820240 NOTICE: Creating Demuxer
17:20:28.697 T:138105820240 NOTICE: Opening stream: 0 source: 256
17:20:28.697 T:138105820240 NOTICE: Creating video codec with codec id: 28
17:20:28.711 T:138105820240 NOTICE: Creating video thread
17:20:28.711 T:138105820240 NOTICE: Opening stream: 1 source: 256
17:20:28.711 T:138118329424 NOTICE: running thread: video_thread
17:20:28.711 T:138105820240 NOTICE: Finding audio codec for: 86057
17:20:28.711 T:138105820240 NOTICE: Creating audio thread
17:20:28.711 T:138136241232 NOTICE: running thread: CVideoPlayerAudio::Process()
17:20:28.722 T:138136241232 NOTICE: Creating audio stream (codec id: 86057, channels: 6, sample rate: 48000, pass-through)
17:20:28.739 T:138055545936 NOTICE: Trying to open: 192000 samplerate 12 channelMask 13 encoding
17:20:28.748 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_EAC3 min_buffer_size: 65600 m_frames: 8200 m_frameSize: 4 channels: 2
17:20:28.776 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:20:28.780 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:20:28.780 T:137670939728 NOTICE: GL: NPOT texture support detected
17:20:28.788 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:20:59.456 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:20:59.456 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:20:59.457 T:138105820240 NOTICE: CVideoPlayer::OnExit()
17:20:59.457 T:138105820240 NOTICE: Closing stream player 1
17:20:59.457 T:138105820240 NOTICE: Waiting for audio thread to exit
17:20:59.577 T:138136241232 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:20:59.577 T:138105820240 NOTICE: Closing audio device
17:20:59.587 T:138105820240 NOTICE: Deleting audio codec
17:20:59.587 T:138105820240 NOTICE: Closing stream player 2
17:20:59.587 T:138105820240 NOTICE: waiting for video thread to exit
17:20:59.589 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:20:59.592 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:20:59.633 T:138118329424 NOTICE: thread end: video_thread
17:20:59.639 T:138105820240 NOTICE: deleting video codec
17:20:59.672 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:20:59.672 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-atmos_amaze.mp4
17:20:59.673 T:138098492496 NOTICE: Creating InputStream
17:20:59.701 T:138098492496 NOTICE: Creating Demuxer
17:20:59.742 T:138098492496 NOTICE: Opening stream: 0 source: 256
17:20:59.742 T:138098492496 NOTICE: Creating video codec with codec id: 28
17:20:59.766 T:138098492496 NOTICE: Creating video thread
17:20:59.766 T:138098492496 NOTICE: Opening stream: 1 source: 256
17:20:59.766 T:138105308240 NOTICE: running thread: video_thread
17:20:59.766 T:138098492496 NOTICE: Finding audio codec for: 86057
17:20:59.766 T:138098492496 NOTICE: Creating audio thread
17:20:59.767 T:138106344528 NOTICE: running thread: CVideoPlayerAudio::Process()
17:20:59.777 T:138106344528 NOTICE: Creating audio stream (codec id: 86057, channels: 6, sample rate: 48000, pass-through)
17:20:59.807 T:138055545936 NOTICE: Trying to open: 192000 samplerate 12 channelMask 13 encoding
17:20:59.814 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_EAC3 min_buffer_size: 65600 m_frames: 8200 m_frameSize: 4 channels: 2
17:20:59.842 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:20:59.865 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:20:59.865 T:137670939728 NOTICE: GL: NPOT texture support detected
17:20:59.873 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:21:36.714 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:21:36.714 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:21:36.715 T:138098492496 NOTICE: CVideoPlayer::OnExit()
17:21:36.715 T:138098492496 NOTICE: Closing stream player 1
17:21:36.715 T:138098492496 NOTICE: Waiting for audio thread to exit
17:21:36.737 T:138106344528 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:21:36.737 T:138098492496 NOTICE: Closing audio device
17:21:36.747 T:138098492496 NOTICE: Deleting audio codec
17:21:36.747 T:138098492496 NOTICE: Closing stream player 2
17:21:36.747 T:138098492496 NOTICE: waiting for video thread to exit
17:21:36.750 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:21:36.753 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:21:36.778 T:138105308240 NOTICE: thread end: video_thread
17:21:36.779 T:138098492496 NOTICE: deleting video codec
17:21:36.807 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:21:36.808 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-atmos_amaze.mp4
17:21:36.810 T:138099528784 NOTICE: Creating InputStream
17:21:36.839 T:138099528784 NOTICE: Creating Demuxer
17:21:36.884 T:138099528784 NOTICE: Opening stream: 0 source: 256
17:21:36.884 T:138099528784 NOTICE: Creating video codec with codec id: 28
17:21:36.912 T:138099528784 NOTICE: Creating video thread
17:21:36.912 T:138099528784 NOTICE: Opening stream: 1 source: 256
17:21:36.912 T:138105308240 NOTICE: running thread: video_thread
17:21:36.912 T:138099528784 NOTICE: Finding audio codec for: 86057
17:21:36.913 T:138099528784 NOTICE: Creating audio thread
17:21:36.916 T:138106344528 NOTICE: running thread: CVideoPlayerAudio::Process()
17:21:36.916 T:138106344528 NOTICE: Creating audio stream (codec id: 86057, channels: 6, sample rate: 48000, pass-through)
17:21:36.951 T:138055545936 NOTICE: Trying to open: 192000 samplerate 12 channelMask 13 encoding
17:21:36.958 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_EAC3 min_buffer_size: 65600 m_frames: 8200 m_frameSize: 4 channels: 2
17:21:36.992 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:21:37.034 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:21:37.034 T:137670939728 NOTICE: GL: NPOT texture support detected
17:21:37.081 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:21:40.112 T:137670939728 NOTICE: NFS is idle. Closing the remaining connections.
17:22:07.900 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:22:07.900 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:22:07.904 T:138099528784 NOTICE: CVideoPlayer::OnExit()
17:22:07.904 T:138099528784 NOTICE: Closing stream player 1
17:22:07.904 T:138099528784 NOTICE: Waiting for audio thread to exit
17:22:07.979 T:138106344528 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:22:07.979 T:138099528784 NOTICE: Closing audio device
17:22:07.988 T:138099528784 NOTICE: Deleting audio codec
17:22:07.989 T:138099528784 NOTICE: Closing stream player 2
17:22:07.989 T:138099528784 NOTICE: waiting for video thread to exit
17:22:07.991 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:22:07.994 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:22:08.003 T:138105308240 NOTICE: thread end: video_thread
17:22:08.004 T:138099528784 NOTICE: deleting video codec
17:22:08.032 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:22:08.033 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-horizon-lossless.m2ts
17:22:08.034 T:138098492496 NOTICE: Creating InputStream
17:22:08.049 T:138098492496 NOTICE: Creating Demuxer
17:22:08.195 T:138098492496 NOTICE: Opening stream: 0 source: 256
17:22:08.195 T:138098492496 NOTICE: Creating video codec with codec id: 28
17:22:08.195 T:138098492496 ERROR: CDVDVideoCodecAndroidMediaCodec::Open - null size, cannot handle
17:22:08.195 T:138098492496 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:22:08.197 T:138098492496 NOTICE: Creating video thread
17:22:08.197 T:138098492496 NOTICE: Opening stream: 1 source: 256
17:22:08.198 T:138098492496 NOTICE: Finding audio codec for: 86061
17:22:08.198 T:138098492496 NOTICE: Creating audio thread
17:22:08.198 T:138116797520 NOTICE: running thread: video_thread
17:22:08.198 T:138118329424 NOTICE: running thread: CVideoPlayerAudio::Process()
17:22:08.222 T:138098492496 NOTICE: Opening stream: 0 source: 256
17:22:08.222 T:138098492496 NOTICE: Creating video codec with codec id: 28
17:22:08.254 T:138098492496 NOTICE: Opening stream: 1 source: 256
17:22:08.260 T:138118329424 NOTICE: Creating audio stream (codec id: 86061, channels: 8, sample rate: 48000, pass-through)
17:22:08.287 T:138055545936 NOTICE: Trying to open: 192000 samplerate 6396 channelMask 13 encoding
17:22:08.302 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_TRUEHD min_buffer_size: 262400 m_frames: 8200 m_frameSize: 16 channels: 8
17:22:08.367 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:22:08.368 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:22:08.369 T:137670939728 NOTICE: GL: NPOT texture support detected
17:22:08.410 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:23:05.855 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:23:05.855 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:23:05.863 T:138098492496 NOTICE: CVideoPlayer::OnExit()
17:23:05.864 T:138098492496 NOTICE: Closing stream player 1
17:23:05.864 T:138098492496 NOTICE: Waiting for audio thread to exit
17:23:06.113 T:138116797520 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
17:23:06.583 T:138118329424 WARNING: Previous line repeats 2 times.
17:23:06.583 T:138118329424 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:23:06.583 T:138098492496 NOTICE: Closing audio device
17:23:06.595 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:23:06.598 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:23:06.604 T:138098492496 NOTICE: Deleting audio codec
17:23:06.604 T:138098492496 NOTICE: Closing stream player 2
17:23:06.604 T:138098492496 NOTICE: waiting for video thread to exit
17:23:06.605 T:138116797520 NOTICE: thread end: video_thread
17:23:06.614 T:138098492496 NOTICE: deleting video codec
17:23:06.660 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:23:06.660 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-horizon-lossless.m2ts
17:23:06.662 T:138099528784 NOTICE: Creating InputStream
17:23:06.760 T:138099528784 NOTICE: Creating Demuxer
17:23:06.847 T:138099528784 NOTICE: Opening stream: 0 source: 256
17:23:06.847 T:138099528784 NOTICE: Creating video codec with codec id: 28
17:23:06.847 T:138099528784 ERROR: CDVDVideoCodecAndroidMediaCodec::Open - null size, cannot handle
17:23:06.847 T:138099528784 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:23:06.850 T:138099528784 NOTICE: Creating video thread
17:23:06.850 T:138099528784 NOTICE: Opening stream: 1 source: 256
17:23:06.850 T:138116797520 NOTICE: running thread: video_thread
17:23:06.850 T:138099528784 NOTICE: Finding audio codec for: 86061
17:23:06.850 T:138099528784 NOTICE: Creating audio thread
17:23:06.851 T:138118329424 NOTICE: running thread: CVideoPlayerAudio::Process()
17:23:06.868 T:138099528784 NOTICE: Opening stream: 0 source: 256
17:23:06.868 T:138099528784 NOTICE: Creating video codec with codec id: 28
17:23:06.899 T:138099528784 NOTICE: Opening stream: 1 source: 256
17:23:06.904 T:138118329424 NOTICE: Creating audio stream (codec id: 86061, channels: 8, sample rate: 48000, pass-through)
17:23:06.911 T:138055545936 NOTICE: Trying to open: 192000 samplerate 6396 channelMask 13 encoding
17:23:06.927 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_TRUEHD min_buffer_size: 262400 m_frames: 8200 m_frameSize: 16 channels: 8
17:23:07.001 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:23:07.002 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:23:07.002 T:137670939728 NOTICE: GL: NPOT texture support detected
17:23:07.043 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:23:38.762 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:23:38.763 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:23:38.765 T:138099528784 NOTICE: CVideoPlayer::OnExit()
17:23:38.765 T:138099528784 NOTICE: Closing stream player 1
17:23:38.765 T:138099528784 NOTICE: Waiting for audio thread to exit
17:23:39.113 T:138116797520 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
17:23:39.473 T:138118329424 WARNING: Previous line repeats 2 times.
17:23:39.473 T:138118329424 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:23:39.473 T:138099528784 NOTICE: Closing audio device
17:23:39.484 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:23:39.487 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:23:39.495 T:138099528784 NOTICE: Deleting audio codec
17:23:39.495 T:138099528784 NOTICE: Closing stream player 2
17:23:39.495 T:138099528784 NOTICE: waiting for video thread to exit
17:23:39.495 T:138116797520 NOTICE: thread end: video_thread
17:23:39.501 T:138099528784 NOTICE: deleting video codec
17:23:39.532 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:23:39.533 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-atmos_amaze.mp4
17:23:39.534 T:138098492496 NOTICE: Creating InputStream
17:23:39.547 T:138098492496 NOTICE: Creating Demuxer
17:23:39.607 T:138098492496 NOTICE: Opening stream: 0 source: 256
17:23:39.607 T:138098492496 NOTICE: Creating video codec with codec id: 28
17:23:39.628 T:138098492496 NOTICE: Creating video thread
17:23:39.628 T:138098492496 NOTICE: Opening stream: 1 source: 256
17:23:39.628 T:138098492496 NOTICE: Finding audio codec for: 86057
17:23:39.628 T:138105308240 NOTICE: running thread: video_thread
17:23:39.628 T:138098492496 NOTICE: Creating audio thread
17:23:39.631 T:138106344528 NOTICE: running thread: CVideoPlayerAudio::Process()
17:23:39.632 T:138106344528 NOTICE: Creating audio stream (codec id: 86057, channels: 6, sample rate: 48000, pass-through)
17:23:39.660 T:138055545936 NOTICE: Trying to open: 192000 samplerate 12 channelMask 13 encoding
17:23:39.667 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_EAC3 min_buffer_size: 65600 m_frames: 8200 m_frameSize: 4 channels: 2
17:23:39.712 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:23:39.740 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:23:39.741 T:137670939728 NOTICE: GL: NPOT texture support detected
17:23:39.782 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:24:19.206 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:24:19.207 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:24:19.207 T:138098492496 NOTICE: CVideoPlayer::OnExit()
17:24:19.207 T:138098492496 NOTICE: Closing stream player 1
17:24:19.207 T:138098492496 NOTICE: Waiting for audio thread to exit
17:24:19.308 T:138106344528 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:24:19.308 T:138098492496 NOTICE: Closing audio device
17:24:19.317 T:138098492496 NOTICE: Deleting audio codec
17:24:19.318 T:138098492496 NOTICE: Closing stream player 2
17:24:19.318 T:138098492496 NOTICE: waiting for video thread to exit
17:24:19.320 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:24:19.323 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:24:19.327 T:138105308240 NOTICE: thread end: video_thread
17:24:19.327 T:138098492496 NOTICE: deleting video codec
17:24:19.364 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:24:19.365 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-horizon-lossless.m2ts
17:24:19.366 T:138099528784 NOTICE: Creating InputStream
17:24:19.382 T:138099528784 NOTICE: Creating Demuxer
17:24:19.554 T:138099528784 NOTICE: Opening stream: 0 source: 256
17:24:19.554 T:138099528784 NOTICE: Creating video codec with codec id: 28
17:24:19.555 T:138099528784 ERROR: CDVDVideoCodecAndroidMediaCodec::Open - null size, cannot handle
17:24:19.555 T:138099528784 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:24:19.557 T:138099528784 NOTICE: Creating video thread
17:24:19.557 T:138099528784 NOTICE: Opening stream: 1 source: 256
17:24:19.557 T:138116797520 NOTICE: running thread: video_thread
17:24:19.557 T:138099528784 NOTICE: Finding audio codec for: 86061
17:24:19.557 T:138099528784 NOTICE: Creating audio thread
17:24:19.557 T:138118329424 NOTICE: running thread: CVideoPlayerAudio::Process()
17:24:19.576 T:138099528784 NOTICE: Opening stream: 0 source: 256
17:24:19.576 T:138099528784 NOTICE: Creating video codec with codec id: 28
17:24:19.604 T:138099528784 NOTICE: Opening stream: 1 source: 256
17:24:19.608 T:138118329424 NOTICE: Creating audio stream (codec id: 86061, channels: 8, sample rate: 48000, pass-through)
17:24:19.617 T:138055545936 NOTICE: Trying to open: 192000 samplerate 6396 channelMask 13 encoding
17:24:19.633 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_TRUEHD min_buffer_size: 262400 m_frames: 8200 m_frameSize: 16 channels: 8
17:24:19.709 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:24:19.709 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:24:19.710 T:137670939728 NOTICE: GL: NPOT texture support detected
17:24:19.751 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:25:17.137 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:25:17.137 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:25:17.137 T:138099528784 NOTICE: CVideoPlayer::OnExit()
17:25:17.137 T:138099528784 NOTICE: Closing stream player 1
17:25:17.138 T:138099528784 NOTICE: Waiting for audio thread to exit
17:25:17.152 T:138118329424 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:25:17.152 T:138099528784 NOTICE: Closing audio device
17:25:17.163 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:25:17.166 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:25:17.174 T:138099528784 NOTICE: Deleting audio codec
17:25:17.175 T:138099528784 NOTICE: Closing stream player 2
17:25:17.175 T:138099528784 NOTICE: waiting for video thread to exit
17:25:17.177 T:138116797520 NOTICE: thread end: video_thread
17:25:17.185 T:138099528784 NOTICE: deleting video codec
17:25:17.217 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:25:17.217 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-atmos_amaze.mp4
17:25:17.221 T:138101601360 NOTICE: Creating InputStream
17:25:17.238 T:138101601360 NOTICE: Creating Demuxer
17:25:17.304 T:138101601360 NOTICE: Opening stream: 0 source: 256
17:25:17.304 T:138101601360 NOTICE: Creating video codec with codec id: 28
17:25:17.326 T:138101601360 NOTICE: Creating video thread
17:25:17.327 T:138101601360 NOTICE: Opening stream: 1 source: 256
17:25:17.327 T:138101601360 NOTICE: Finding audio codec for: 86057
17:25:17.327 T:138101601360 NOTICE: Creating audio thread
17:25:17.327 T:138106344528 NOTICE: running thread: video_thread
17:25:17.331 T:138114724944 NOTICE: running thread: CVideoPlayerAudio::Process()
17:25:17.332 T:138114724944 NOTICE: Creating audio stream (codec id: 86057, channels: 6, sample rate: 48000, pass-through)
17:25:17.376 T:138055545936 NOTICE: Trying to open: 192000 samplerate 12 channelMask 13 encoding
17:25:17.381 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_EAC3 min_buffer_size: 65600 m_frames: 8200 m_frameSize: 4 channels: 2
17:25:17.415 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:25:17.442 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:25:17.442 T:137670939728 NOTICE: GL: NPOT texture support detected
17:25:17.485 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:25:54.354 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:25:54.354 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:25:54.357 T:138101601360 NOTICE: CVideoPlayer::OnExit()
17:25:54.357 T:138101601360 NOTICE: Closing stream player 1
17:25:54.357 T:138101601360 NOTICE: Waiting for audio thread to exit
17:25:54.521 T:138114724944 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:25:54.521 T:138101601360 NOTICE: Closing audio device
17:25:54.531 T:138101601360 NOTICE: Deleting audio codec
17:25:54.531 T:138101601360 NOTICE: Closing stream player 2
17:25:54.531 T:138101601360 NOTICE: waiting for video thread to exit
17:25:54.533 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:25:54.536 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:25:54.554 T:138106344528 NOTICE: thread end: video_thread
17:25:54.558 T:138101601360 NOTICE: deleting video codec
17:25:54.583 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:25:54.583 T:137670939728 NOTICE: VideoPlayer: Opening: /storage/NAS/Vidéos/Demo Trailers (HD)/Atmos/dolby-horizon-lossless.m2ts
17:25:54.586 T:138098492496 NOTICE: Creating InputStream
17:25:54.637 T:138098492496 NOTICE: Creating Demuxer
17:25:54.786 T:138098492496 NOTICE: Opening stream: 0 source: 256
17:25:54.786 T:138098492496 NOTICE: Creating video codec with codec id: 28
17:25:54.786 T:138098492496 ERROR: CDVDVideoCodecAndroidMediaCodec::Open - null size, cannot handle
17:25:54.786 T:138098492496 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:25:54.787 T:138098492496 NOTICE: Creating video thread
17:25:54.788 T:138098492496 NOTICE: Opening stream: 1 source: 256
17:25:54.788 T:138118329424 NOTICE: running thread: video_thread
17:25:54.788 T:138098492496 NOTICE: Finding audio codec for: 86061
17:25:54.788 T:138098492496 NOTICE: Creating audio thread
17:25:54.798 T:138136241232 NOTICE: running thread: CVideoPlayerAudio::Process()
17:25:54.832 T:138098492496 NOTICE: Opening stream: 0 source: 256
17:25:54.833 T:138098492496 NOTICE: Creating video codec with codec id: 28
17:25:54.869 T:138098492496 NOTICE: Opening stream: 1 source: 256
17:25:54.881 T:138136241232 NOTICE: Creating audio stream (codec id: 86061, channels: 8, sample rate: 48000, pass-through)
17:25:54.918 T:138055545936 NOTICE: Trying to open: 192000 samplerate 6396 channelMask 13 encoding
17:25:54.934 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_TRUEHD min_buffer_size: 262400 m_frames: 8200 m_frameSize: 16 channels: 8
17:25:54.954 T:137670939728 NOTICE: Using GL_TEXTURE_2D
17:25:54.958 T:137670939728 NOTICE: GL: Using MediaCodec (Surface) render method
17:25:54.958 T:137670939728 NOTICE: GL: NPOT texture support detected
17:25:54.999 T:137670939728 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.000000 - Full Screen (23) (weight: 0.000)
17:26:33.779 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:26:33.779 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:26:33.785 T:138098492496 NOTICE: CVideoPlayer::OnExit()
17:26:33.785 T:138098492496 NOTICE: Closing stream player 1
17:26:33.785 T:138098492496 NOTICE: Waiting for audio thread to exit
17:26:34.027 T:138136241232 NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:26:34.027 T:138098492496 NOTICE: Closing audio device
17:26:34.037 T:138055545936 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
17:26:34.039 T:138055545936 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 30208 m_frames: 1888 m_frameSize: 8 channels: 2
17:26:34.045 T:138098492496 NOTICE: Deleting audio codec
17:26:34.045 T:138098492496 NOTICE: Closing stream player 2
17:26:34.045 T:138098492496 NOTICE: waiting for video thread to exit
17:26:34.077 T:138118329424 NOTICE: thread end: video_thread
17:26:34.082 T:138098492496 NOTICE: deleting video codec
17:26:34.116 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:26:34.145 T:137670939728 NOTICE: CVideoPlayer::CloseFile()
17:26:34.145 T:137670939728 NOTICE: VideoPlayer: waiting for threads to exit
17:26:34.145 T:137670939728 NOTICE: VideoPlayer: finished waiting
17:26:34.907 T:138101601360 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
