Using ES File explorer I have saved my current BG Nova build on a zip drive. My android box is running 6.0. If I upgrade to Kodi 17 Krypton, can I just paste my backup in the appropriate Kodi file so I don't have to do a total re-build by hand?
Upgrading from Jarvis to Krypton will upgrade your current video and music database into new databases. No current databases will be deleted. Other than that, your data will be not be touched. Data backups can always be handy though.
So I just download it from the Playstore. Open it up, pick save prior settings etc., and it downloads over the prior Jarvis edition and then I download and pick the B G Nova skin and everything is there? Thank you.
