Full Version: Can't find help with my issue
Kodi had been working fine on my pc, last night I upgraded to windows 10 and it continued to work fine. This morning however when I started my pc and launched kodi, it's become buggy. The cursor and screen are all off center and it looks almost like it's trying to display in 3d, which it's not as I have already checked to make sure that option is not selected. I'm not really sure how to describe the issue, so here's a picture of the problem https://m.imgur.com/account/Cgesus/images/SDabaAQ
When I try to switch from full screen to windowed, it goes to a blank blue screen. Thanks in advance
Can you try again with the screenshot, please - I get a 404 when I follow that.
It may also be worth grabbing a debug log (wiki), as that will help explain what's happening. If you can't turn on logging through the application, then you'll need to use the advancedsettings.xml (wiki) approach.
I'm not sure why the link isn't working directly, for some reason clicking it doesn't work, but copying and pasting the link does? I'll try to get a debug log
Looks like your Kodi box is drunk.
https://imgur.com/SDabaAQ
I fixed it, just needed a driver update for my graphic card.. Simplest of solutions haha
Thread marked solved.
Nvidia GPU is it? the 3D Vision drivers are well known for causing such issues.
