Full Version: Kodi 17.3 black screen when selecting HDMI
This started happening after a recent upgrade on a standalone Kodi setup on an Arch Linux 4.11.9 box with Intel graphics. Kodi boots with the "default" monitor selected to 1024x768p and trying to switch output to HDMI ends up with a blank screen - apparently it is unable to create a window for it.
Debug log: https://pastebin.com/cHnvhkKK . The relevant log section is:
11:01:03.699 T:139857538512192 NOTICE: Using visual 0x20
11:01:03.713 T:139857538512192 ERROR: failed to create EGL window surface 12293
11:01:03.713 T:139857538512192 INFO: GL: Maximum texture width: 32768
11:01:03.713 T:139857538512192 ERROR: ResetRenderSystem() GL_MAX_TEXTURE_IMAGE_UNITS_ARB returned invalid value 22076
11:01:03.713 T:139856944555776 DEBUG: CActiveAE - display reset event
What caught my eye is the value reported by GL_MAX_TEXTURE_IMAGE_UNITS_ARB, because xrandr confirms it is set to 32:
$ glxinfo -l -display :0.0
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
    GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
    GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
    GLX_SGI_make_current_read, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
    GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
    GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Intel Open Source Technology Center (0x8086)
    Device: Mesa DRI Intel(R) HD Graphics 400 (Braswell)  (0x22b1)
    Version: 17.1.4
    Accelerated: yes
    Video memory: 1536MB
    Unified memory: yes
    Preferred profile: core (0x1)
    Max core profile version: 4.5
    Max compat profile version: 3.0
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.1
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 400 (Braswell)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 17.1.4
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
    GL_3DFX_texture_compression_FXT1, GL_AMD_conservative_depth,
    GL_AMD_draw_buffers_blend, GL_AMD_seamless_cubemap_per_texture,
    GL_AMD_shader_trinary_minmax, GL_AMD_vertex_shader_layer,
    GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3,
    GL_ANGLE_texture_compression_dxt5, GL_APPLE_object_purgeable,
    GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
    GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
    GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_blend_func_extended,
    GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
    GL_ARB_clip_control, GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_compute_shader, GL_ARB_conditional_render_inverted,
    GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
    GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
    GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_direct_state_access,
    GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
    GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
    GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
    GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
    GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
    GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
    GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
    GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
    GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
    GL_ARB_multi_draw_indirect, GL_ARB_occlusion_query2,
    GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
    GL_ARB_point_sprite, GL_ARB_program_interface_query,
    GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
    GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
    GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
    GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
    GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters,
    GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
    GL_ARB_shader_draw_parameters, GL_ARB_shader_image_load_store,
    GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision,
    GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
    GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
    GL_ARB_shader_viewport_layer_array, GL_ARB_shading_language_420pack,
    GL_ARB_shading_language_packing, GL_ARB_stencil_texturing, GL_ARB_sync,
    GL_ARB_tessellation_shader, GL_ARB_texture_barrier,
    GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
    GL_ARB_texture_buffer_range, GL_ARB_texture_compression_bptc,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array,
    GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample,
    GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
    GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
    GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
    GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
    GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
    GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
    GL_ARB_transform_feedback_instanced,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object,
    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
    GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_shader, GL_ARB_vertex_type_10f_11f_11f_rev,
    GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array,
    GL_ATI_blend_equation_separate, GL_ATI_texture_float, GL_EXT_abgr,
    GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,
    GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
    GL_EXT_framebuffer_sRGB, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
    GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_shader_integer_mix,
    GL_EXT_shader_samples_identical, GL_EXT_texture_array,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_anisotropic,
    GL_EXT_texture_integer, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
    GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
    GL_EXT_vertex_array_bgra, GL_IBM_multimode_draw_arrays,
    GL_INTEL_performance_query, GL_KHR_blend_equation_advanced,
    GL_KHR_context_flush_control, GL_KHR_debug,
    GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
    GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
    GL_MESA_texture_signed_rgba, GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_NV_packed_depth_stencil, GL_NV_texture_barrier, GL_OES_EGL_image,
    GL_S3_s3tc
OpenGL core profile limits:
    GL_MAX_ATTRIB_STACK_DEPTH = 16
    GL_MAX_CLIENT_ATTRIB_STACK_DEPTH = 16
    GL_MAX_CLIP_PLANES = 8
    GL_MAX_ELEMENTS_VERTICES = 3000
    GL_MAX_ELEMENTS_INDICES = 3000
    GL_MAX_EVAL_ORDER = 30
    GL_MAX_LIGHTS = 8
    GL_MAX_LIST_NESTING = 64
    GL_MAX_MODELVIEW_STACK_DEPTH = 32
    GL_MAX_NAME_STACK_DEPTH = 64
    GL_MAX_PIXEL_MAP_TABLE = 256
    GL_MAX_PROJECTION_STACK_DEPTH = 32
    GL_MAX_TEXTURE_STACK_DEPTH = 10
    GL_MAX_TEXTURE_SIZE = 16384
    GL_MAX_3D_TEXTURE_SIZE = 2048
    GL_MAX_ARRAY_TEXTURE_LAYERS = 2048
    GL_MAX_VIEWPORT_DIMS = 32768, 32768
    GL_ALIASED_LINE_WIDTH_RANGE = 1, 7
    GL_SMOOTH_LINE_WIDTH_RANGE = 1, 7
    GL_ALIASED_POINT_SIZE_RANGE = 1, 255
    GL_SMOOTH_POINT_SIZE_RANGE = 1, 255
    GL_MAX_TEXTURE_MAX_ANISOTROPY_EXT = 16
    GL_MAX_DRAW_BUFFERS_ARB = 8
    GL_MAX_DUAL_SOURCE_DRAW_BUFFERS = 1
    GL_MAX_RENDERBUFFER_SIZE = 16384
    GL_MAX_COLOR_ATTACHMENTS = 8
    GL_MAX_SAMPLES = 8
    GL_MAX_TRANSFORM_FEEDBACK_BUFFERS = 4
    GL_MAX_TRANSFORM_FEEDBACK_INTERLEAVED_COMPONENTS = 64
    GL_MAX_TRANSFORM_FEEDBACK_SEPARATE_ATTRIBS = 4
    GL_MAX_TRANSFORM_FEEDBACK_SEPARATE_COMPONENTS = 16
    GL_TEXTURE_BUFFER_OFFSET_ALIGNMENT = 16
    GL_MAX_TEXTURE_BUFFER_SIZE = 134217728
    GL_MAX_COLOR_TEXTURE_SAMPLES = 8
    GL_MAX_DEPTH_TEXTURE_SAMPLES = 8
    GL_MAX_INTEGER_SAMPLES = 8
    GL_MAX_VERTEX_UNIFORM_BLOCKS = 14
    GL_MAX_FRAGMENT_UNIFORM_BLOCKS = 14
    GL_MAX_GEOMETRY_UNIFORM_BLOCKS = 14
    GL_MAX_COMBINED_UNIFORM_BLOCKS = 84
    GL_MAX_UNIFORM_BUFFER_BINDINGS = 84
    GL_MAX_UNIFORM_BLOCK_SIZE = 65536
    GL_MAX_COMBINED_VERTEX_UNIFORM_COMPONENTS = 245760
    GL_MAX_COMBINED_FRAGMENT_UNIFORM_COMPONENTS = 245760
    GL_MAX_COMBINED_GEOMETRY_UNIFORM_COMPONENTS = 245760
    GL_UNIFORM_BUFFER_OFFSET_ALIGNMENT = 16
    GL_MAX_VERTEX_ATTRIB_RELATIVE_OFFSET = 2047
    GL_MAX_VERTEX_ATTRIB_BINDINGS = 16
    GL_MAX_VERTEX_ATTRIB_STRIDE = 2048
    GL_VERTEX_SHADER_ARB:
        GL_MAX_VERTEX_UNIFORM_COMPONENTS_ARB = 16384
        GL_MAX_VARYING_FLOATS_ARB = 128
        GL_MAX_VERTEX_ATTRIBS_ARB = 16
        GL_MAX_TEXTURE_IMAGE_UNITS_ARB = 32
        GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS_ARB = 32
        GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS_ARB = 192
        GL_MAX_TEXTURE_COORDS_ARB = 8
        GL_MAX_VERTEX_OUTPUT_COMPONENTS   = 128
    GL_FRAGMENT_SHADER_ARB:
        GL_MAX_FRAGMENT_UNIFORM_COMPONENTS_ARB = 16384
        GL_MAX_FRAGMENT_INPUT_COMPONENTS  = 128
    GL_GEOMETRY_SHADER:
        GL_MAX_GEOMETRY_UNIFORM_COMPONENTS = 16384
        GL_MAX_GEOMETRY_TEXTURE_IMAGE_UNITS = 32
        GL_MAX_GEOMETRY_OUTPUT_VERTICES   = 256
        GL_MAX_GEOMETRY_TOTAL_OUTPUT_COMPONENTS = 1024
        GL_MAX_GEOMETRY_INPUT_COMPONENTS  = 64
        GL_MAX_GEOMETRY_OUTPUT_COMPONENTS = 128
OpenGL version string: 3.0 Mesa 17.1.4
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
    GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3,
    GL_APPLE_packed_pixels, GL_APPLE_vertex_array_object,
    GL_ARB_ES2_compatibility, GL_ARB_ES3_compatibility,
    GL_ARB_arrays_of_arrays, GL_ARB_blend_func_extended,
    GL_ARB_clip_control, GL_ARB_color_buffer_float,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
    GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
    GL_ARB_depth_texture, GL_ARB_derivative_control, GL_ARB_draw_buffers,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_draw_instanced, GL_ARB_explicit_attrib_location,
    GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_occlusion_query2, GL_ARB_pipeline_statistics_query,
    GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
    GL_ARB_query_buffer_object, GL_ARB_robust_buffer_access_behavior,
    GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
    GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
    GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
    GL_ARB_shader_atomic_counters, GL_ARB_shader_bit_encoding,
    GL_ARB_shader_clock, GL_ARB_shader_draw_parameters,
    GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
    GL_ARB_shader_storage_buffer_object, GL_ARB_shader_texture_image_samples,
    GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
    GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,
    GL_ARB_shadow, GL_ARB_stencil_texturing, GL_ARB_sync,
    GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
    GL_ARB_texture_stencil8, GL_ARB_texture_storage,
    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
    GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
    GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
    GL_ATI_separate_stencil, GL_ATI_texture_env_combine3,
    GL_ATI_texture_float, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_copy_texture, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
    GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_polygon_offset, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shader_integer_mix,
    GL_EXT_shader_samples_identical, GL_EXT_shadow_funcs,
    GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture,
    GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_array,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
    GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
    GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
    GL_MESA_texture_signed_rgba, GL_MESA_window_pos, GL_NV_blend_square,
    GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_light_max_exponent,
    GL_NV_packed_depth_stencil, GL_NV_primitive_restart,
    GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
    GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL limits:
    GL_MAX_LIGHTS = 8
    GL_MAX_CUBE_MAP_TEXTURE_SIZE_ARB = 16384
    GL_MAX_RECTANGLE_TEXTURE_SIZE_NV = 16384
    GL_MAX_TEXTURE_UNITS_ARB = 8
    GL_MAX_TEXTURE_LOD_BIAS_EXT = 15
    GL_MAX_SAMPLES = 8
    GL_NUM_COMPRESSED_TEXTURE_FORMATS = 12
        GL_COMPRESSED_RGB_FXT1_3DFX
        GL_COMPRESSED_RGBA_FXT1_3DFX
        GL_COMPRESSED_RGB_S3TC_DXT1_EXT
        GL_COMPRESSED_RGBA_S3TC_DXT3_EXT
        GL_COMPRESSED_RGBA_S3TC_DXT5_EXT
        GL_COMPRESSED_RGB8_ETC2
        GL_COMPRESSED_RGBA8_ETC2_EAC
        GL_COMPRESSED_R11_EAC
        GL_COMPRESSED_RG11_EAC
        GL_COMPRESSED_SIGNED_R11_EAC
        GL_COMPRESSED_SIGNED_RG11_EAC
        GL_COMPRESSED_RGB8_PUNCHTHROUGH_ALPHA1_ETC2
    GL_VERTEX_PROGRAM_ARB:
        GL_MAX_PROGRAM_INSTRUCTIONS_ARB = 16384
        GL_MAX_PROGRAM_NATIVE_INSTRUCTIONS_ARB = 16384
        GL_MAX_PROGRAM_TEMPORARIES_ARB = 256
        GL_MAX_PROGRAM_NATIVE_TEMPORARIES_ARB = 256
        GL_MAX_PROGRAM_PARAMETERS_ARB = 4096
        GL_MAX_PROGRAM_NATIVE_PARAMETERS_ARB = 1024
        GL_MAX_PROGRAM_ATTRIBS_ARB = 16
        GL_MAX_PROGRAM_NATIVE_ATTRIBS_ARB = 16
        GL_MAX_PROGRAM_ADDRESS_REGISTERS_ARB = 1
        GL_MAX_PROGRAM_NATIVE_ADDRESS_REGISTERS_ARB = 1
        GL_MAX_PROGRAM_LOCAL_PARAMETERS_ARB = 4096
        GL_MAX_PROGRAM_ENV_PARAMETERS_ARB = 256
    GL_FRAGMENT_PROGRAM_ARB:
        GL_MAX_PROGRAM_NATIVE_INSTRUCTIONS_ARB = 1024
        GL_MAX_PROGRAM_PARAMETERS_ARB = 64
        GL_MAX_PROGRAM_ATTRIBS_ARB = 12
        GL_MAX_PROGRAM_NATIVE_ATTRIBS_ARB = 12
        GL_MAX_PROGRAM_ADDRESS_REGISTERS_ARB = 0
        GL_MAX_PROGRAM_NATIVE_ADDRESS_REGISTERS_ARB = 0
        GL_MAX_PROGRAM_ALU_INSTRUCTIONS_ARB = 16384
        GL_MAX_PROGRAM_TEX_INSTRUCTIONS_ARB = 16384
        GL_MAX_PROGRAM_TEX_INDIRECTIONS_ARB = 16384
        GL_MAX_PROGRAM_NATIVE_ALU_INSTRUCTIONS_ARB = 1024
        GL_MAX_PROGRAM_NATIVE_TEX_INSTRUCTIONS_ARB = 1024
        GL_MAX_PROGRAM_NATIVE_TEX_INDIRECTIONS_ARB = 1024
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 17.1.4
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
    GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
    GL_APPLE_texture_max_level, GL_EXT_blend_func_extended,
    GL_EXT_blend_minmax, GL_EXT_buffer_storage, GL_EXT_clip_cull_distance,
    GL_EXT_color_buffer_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
    GL_EXT_copy_image, GL_EXT_discard_framebuffer, GL_EXT_draw_buffers,
    GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
    GL_EXT_frag_depth, GL_EXT_geometry_point_size, GL_EXT_geometry_shader,
    GL_EXT_gpu_shader5, GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
    GL_EXT_polygon_offset_clamp, GL_EXT_primitive_bounding_box,
    GL_EXT_read_format_bgra, GL_EXT_robustness,
    GL_EXT_separate_shader_objects, GL_EXT_shader_integer_mix,
    GL_EXT_shader_io_blocks, GL_EXT_shader_samples_identical,
    GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
    GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_cube_map_array,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_format_BGRA8888,
    GL_EXT_texture_rg, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_unpack_subimage,
    GL_MESA_shader_integer_functions, GL_NV_draw_buffers,
    GL_NV_fbo_color_attachments, GL_NV_image_formats, GL_NV_read_buffer,
    GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
    GL_OES_EGL_image, GL_OES_EGL_image_external, GL_OES_EGL_sync,
    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
    GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
    GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
    GL_OES_geometry_point_size, GL_OES_geometry_shader,
    GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
    GL_OES_rgb8_rgba8, GL_OES_sample_shading, GL_OES_sample_variables,
    GL_OES_shader_image_atomic, GL_OES_shader_io_blocks,
    GL_OES_shader_multisample_interpolation, GL_OES_standard_derivatives,
    GL_OES_stencil8, GL_OES_surfaceless_context,
    GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
    GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_buffer,
    GL_OES_texture_cube_map_array, GL_OES_texture_float,
    GL_OES_texture_float_linear, GL_OES_texture_half_float,
    GL_OES_texture_half_float_linear, GL_OES_texture_npot,
    GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
    GL_OES_vertex_array_object, GL_OES_vertex_half_float,
    GL_OES_viewport_array
40 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x020 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x021 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0d1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0d2 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0d3 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0d4 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0d5 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0d6 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0d7 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0d8 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0d9 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0da 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0db 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0dc 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x0dd 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x0de 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x0df 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x0e0 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x0e1 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x0e2 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x0e3 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x0e4 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0e5 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0e6 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0e7 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0e8 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0e9 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0ea 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0eb 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ec 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0ed 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0ee 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0ef 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x0f0 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x0f1 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x0f2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x0f3 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x0f4 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x0f5 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x0f6 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
64 GLXFBConfigs:
0x091  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x092  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x093  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x094  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x095  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x096  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x097 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x098 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x099 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x09a 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x09b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x09c 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x09d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x09e 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x09f  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0a0  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0a1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0a2 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0a3 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a4 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0a5  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  4 1 None
0x0a6  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  8 1 None
0x0a7  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  4 1 None
0x0a8  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  8 1 None
0x0a9 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x0aa 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x0ab 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x0ac 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x0ad 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x0ae 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x0af 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x0b0 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x0b1  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0b2  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0b3  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0b4  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0b5  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0b6  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0b7 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0b8 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0b9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ba 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0bb 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0bc 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0bd 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0be 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0bf  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0c0  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0c1 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0c2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0c3 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0c4 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0c5  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  4 1 None
0x0c6  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  8 1 None
0x0c7  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  4 1 None
0x0c8  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  8 1 None
0x0c9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x0ca 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x0cb 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x0cc 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x0cd 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x0ce 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x0cf 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x0d0 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
Any suggestions to tackle this issue? It made my media center useless overnight Sad
PS: Downgrading different system components (mesa, vulkan-intel, linux, kodi itself) doesn't seem to help.
