2017-07-13, 23:09
2017-07-13, 23:11
Yes you can. See section 4 here... http://kodi.wiki/view/Subtitle
2017-07-13, 23:18
i am sorry but can you show me where it is
because i can't find it
i mean can i download them through the home screen or through an add on
2017-07-13, 23:31
Subtitle providers have their addon you can download. Install it and select the subtitle provider in the Language section of the Player settings.
EDIT: and yes, that wiki page on subtitles does need some updating
2017-07-14, 00:04
but can't download them until i play the video
what i want is to download the subtitle in the home screen and then playing it in the external player
2017-07-14, 00:07
What do you mean by External Player?
And I suppose that is what happens when you are not clear with your question. I read your original question as just wanting to manually download a subtitle file... outside of Kodi
2017-07-14, 00:16
sorry if i don't write my question well
i am using kodi and play the movies from kodi but not with kodi media player i use mx player
what i want is download subtitle within kodi without playing the kodi media player
2017-07-14, 01:33
The internal Kodi addons for subtitles get their info from a running video. If that becomes an external player, I don't think those addons still work. You could have a look at FileBot, it's a standalone application that, amongst other things, can download subtitles.
2017-07-14, 01:41
OK thanks
i will give it a try
2017-07-14, 11:27
You could install the subtitle dialog context menu add-on. That way you go to the movie list, open the context menu for that item you are positioned on and download the subtitles you need.
https://github.com/burekas7/context.subt.../README.md
That is if you are using Kodi!
2017-07-18, 16:08
thank you for post but i download an it says subscene error log?
2017-07-18, 16:23
It only works with some subtitle add-ons, they're mentioned in the description.
Also I believe opensubtitles by opensubtitles works -- not sure about the one in the kodi repo.
2017-07-19, 00:36
i have tried all the add-on subtitle service is all says no subtitle found or error log
2017-07-19, 10:21
Anyways, I never really liked this addon.
Give the autosubs addon a try. It automatically downloads a subtitle when starting your movie.
