Full Version: Need help with installing spotify and IPTV
I am trying to install spotify but all the tutorials contain a step I cannot perform:
Open Kodi
Select SYSTEM
Select Add-Ons
Select Install from zip file <-- I can't do this
I am using a Raspberry Pi3 with latest Raspbian and I sudo apt-get installed kodi.
I am also trying to install a simple IPTV client which supposedly should be avaible from the repository... it cannot be found, it is simply not there and I don't know why.
Can somebody help me out?
Your Photobucket image doesn't work... Use Imgur.com instead.
