Full Version: create a custom hub
as I'm new with this skin and kodi in particular I have a question.
for some time now i'm trying to work with the custom hubs, I saw that some custom hubs have hub sub categories and some don't have - don't mix up with the sub menu, how do I create a hub with some categories in it?
Thank you
In the customisation screen, if you click on "Hub Items" you can add the right side categories there.
What I mean is that I build a hub that I could customized the hub item, I might don't understand correctly what you said so I add a screen shot.
the skin I used is in Hebrew....
http://i.imgur.com/4qLnhEm.jpg
