Full Version: WeTekPlay2 and Kodi playback
All,
I have a WeTekPlay2 (https://wetek.com/product/wetek-play2) which comes with Kodi 16.1 pre-installed and is able play all my home video recordings taken on my Sony RX100 Mrk IV digital camera perfectly smoothly. WeTek package Kodi 16.1 up and call it WePlayer . I have also installed Kodi 17.3 and the same video files do not play back smoothly at all. There is a lot of buffering, stuttering and scenes just don't look right. I have tried changing the player settings for Refresh rate to Always and Start/Stop, but this has made no difference. Are there any other settings I can look into to get smooth playback?
WeTekPlay2 use the Quad-core (Amlogic S905H) CPU, are there any settings to use Hardware acceleration for this CPU?
Thanks in advanced
rajmsuk
There's a big thread with a lot of info on the Wetek Play2 here https://forum.kodi.tv/showthread.php?tid=263373
I use a Wetek Hub which is a very similar device & works perfectly with Kodi 17.3, but the info you need will likely be in the thread above.
(2017-07-18, 16:39)FXB78 Wrote: [ -> ]There's a big thread with a lot of info on the Wetek Play2 here https://forum.kodi.tv/showthread.php?tid=263373
Thanks for your reply. I will take a look at that link. Did you need to change any settings to get videos to playback fine or it is an out of the box setup?
(2017-07-18, 16:42)rajmsuk Wrote: [ -> ]Hi,
I'm not sure about out of the box as I installed a custom ROM on there, I did this as the refresh rate switching was a bit flaky on the WeOS ROM. I believe there are some custom ROM's for the Play2, you'll probably find more info in the thread.
