Full Version: Mac Mini Doesn't See Zip Files
I've just installed Kodi Kryptonite 17.3 on my Mac Mini (macOS Sierra) and the installation went fine. I can successfully add sources but when I attempt to "Install from zip file" the zip files don't show up. The paths are typed correctly. Only a single add-on has been installed. At a slight crossroads...
(2017-07-19, 22:49)lyte.iize Wrote: [ -> ]The paths are typed correctly.
OK, what are the paths?
