Hi, is there a way on a android device to run both Stable 17.4 and Alpha 18? Like to try straight off the press but also like to have a working stable version
Actually there is - its called easy Dual boot Android Marshmallow / LibreELEC Kodi Leia.
And the only competent Android Firmware for stable Kodi Krypton 17.4 running from internal storage, and Kodi Leia Alpha running from a external micro SDHC card are the WeTek Hub and Play2.
A little birdy told me there is a SPMC Krypton 17.x version under testing as well that can be installed along side Kodi Leia Alpha
None of those two you could classify as stable yet.
Using Nvidia shield, have 2 versions of SPMC was hoping could do the same with kodi . But thats okay ill wait until 18 is more stable . thanks
