Full Version: Lircmap.xml and Universal Remote Controls
I have been setting up my remote control and had a few buttons left over with weren't in lircmap.xml. First of all I tried to add custom buttons such as
<custom1>toggle</custom1>
<custom2>ARC</custom2>
However these don't work.
After looking through the keymap.xml I did manage to add three more custom buttons with the labels.
<clear></clear>
<hash></hash>
<star></star>
There is also
<enter></enter> but this only allows the button to be "select"
Does anyone else have any tips on adding extra buttons to lircmap.xml or
[FEATURE REQUEST]
can any developers add a few label options such as:
<custom1></custom1>
through to
<custom20></custom20>
[FEATURE REQUEST]
Cheers
Nick
Nick8888 Wrote:[FEATURE REQUEST]
<custom1></custom1>
through to
[FEATURE REQUEST]
I had exactly the same problem, that's why I patched the source code myself. You can download the patch from http://trac.xbmc.org/ticket/5384
Instead of using the normal names for your buttons, you now tag them as <obc0> - <obc254>. So your Lircmap.xml could look like this:
<obc1>Left</obc1>
<obc2>Right</obc2>
<obc3>Up</obc3>
<obc4>Down</obc4>
You can then use these obc tags to assign XBMC actions in Keymap.xml.
Temar
