Full Version: Looses some configurations
I have 2 nvidia boxes and 2 sony smart tvs and ramdomily each of them looses some configuration settings after restart , like regional settings, option update library on startup, etc...
The settings also enter in standard mode instead of expert.
Thanks,
It could be caused by incorrectly shutting down Kodi.
Do you properly exit Kodi via Kodi's power menu or do you simply switch off the box? Kodi only saves setting on proper shutdown.
Most of the times switch off the box.
Well now you know not to.
