So I'm reading
here in the wiki, and I really wanna do this but it just seems incredibly complicated for my feeble mind. Is there anyone with a modified home.xml who'd be willing to send it to me? All I really want is for Videos to be on top of the list, the rest of the order doesn't matter too much to me (but if I was picky, I'd go with Videos, Programs, Music, Pictures, Weather).
You could actually just post the code in your reply, I could work with that.
(In the mean time, I'm gonna post a recommendation in the feature request forum about adding a "Move up"/"Move down" option for the main menu, kinda like how favourites works.)
Start by swapping the programs and videos options over:
1. Find the programs and video buttons in the xml.
2. Swap over their <label> and <onclick> functions.
3. Done.
Not really that hard now is it?
jmarshall Wrote:Start by swapping the programs and videos options over:
3. Done.
Whoa, if it's that easy why did the wiki make it so complicated?
And will this keep the right image graphics for Videos and Programs or will I have to switch those too?
you will need to switch them too
Yeah, swap over their <visible> conditions should do the trick I think.
What resolution are you editing? I was going to make one but then I realized its different depending on aspect ratio...
SleepyP Wrote:What resolution are you editing? I was going to make one but then I realized its different depending on aspect ratio...
Hey thanks! 16:9
Maybe
this will work? Alls I did was swap Programs and Videos. I pulled Home from PAL16x9 in the SourceForge SVN browser and used NotePad2 to do this.
SleepyP Wrote:Maybe this will work? Alls I did was swap Programs and Videos. I pulled Home from PAL16x9 in the SourceForge SVN browser and used NotePad2 to do this.
Hey it worked perfectly! Now if I copy that home.xml to the 4:3 folder would it work just the same do you think?
No because the position tags are different. Its super easy to do though, you only need to swap #2 and #5 in the multiimage controls at the top of the document, and then swap the label and activation code for the two buttons further down in the document. Its like 6 changes total.
Don't forget to save a backup somewhere, since once you copy a new version of XBMC, you will loose that addition again. Or if you build your own, put that file inside the proper location of the custom directory (if using XBMCDBR)
