I am running
Kodi 17.3 on
OSX 10.12.4 using skin
Estuary Mod (Kodi 17).
For the most part Kodi runs jsut fine, but when playing some (not all) videos from a local USB drive, Kodi crashes / quits upon video completion.
I have simulated this in the below log by skipping to the end of the video.
Debug log:
https://pastebin.com/VLWVK732
The obvious final error line which I can see is
ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true, however I have no idea what that means or how to resolve it. I have tried wiping Kodi (deleting all folders) and starting again from scratch, but this issue still seems to creep back in.
Any assistance provided would be very much apreciated.
Thank you
I think this is fixed in current nightly builds for kodi 18. Our videoplayer developer is focusing on kodi 18 already, so there is no fix expected for kodi 17.x
I also have this problem with kodi 17. I run it on ubuntu 16 and at some point it will crash.
This is the log just before the crash.
Run on raspberry 3 with RaspbianLite OS, kodi15 with the same addons will run for days without any problems. Is this expected? Is this hardware related?
I have the exact same problem! Does anyone have a fix?
I have the same problem anyone fixed
Kodi 17.6
When i playing my pvr iptv m3u playlist every 10-15min is kicking me off with error ending got msgq abort or msgo is error
Befote that player is trying connect many time to somewhere bit cant get it
It says
Getdirectory error getting directory then
Previous lines repeats 3 times (like that few times) then on the end is this one "got msgq error or abort
Please help anyoneee
Ive got old kodi 16.x on the other android box and is working fine
Has anyone suddenly had this problem crop back up again with 18.4? A 2.5 hour movie stopped three times on me today (Nvidia Shield with Windows 10 and SMB3). I had this problem over a year ago, but it seemed to be the CEC controls on the Shield somehow causing it as it went away when I turned them off (they're still off).
this regularly happens to me. Libreelec 9.2.8 with kodi 18.9, Raspberry Pi 4B. The picture freezes, I have to login with ssh and restart kodi
Quote:Code:
raspiwohnen:~/.kodi/temp # grep MSGQ_AB kodi.log
2022-02-28 20:15:00.161 T:2129314624 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
2022-02-28 20:34:30.242 T:2024796992 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2022-02-28 20:34:30.250 T:2016404288 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
2022-02-28 21:16:13.635 T:2192601920 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2022-02-28 21:16:13.647 T:2071982912 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
2022-02-28 21:16:37.447 T:2016404288 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
2022-02-28 21:39:42.844 T:2008011584 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
2022-02-28 22:34:14.101 T:1991226176 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
