Full Version: hevc 10bit support in HW(gpu)?
Hello,
I have noticed that kodi 17.3 does not play hevc 10bit(ultra hd) movies with hardware acceleration.
With hevc 8bit movies, no problem.
Will there be any support for 10bit(dxva)?
Also checked this with mediainfo and within kodi with the "o" key.
I'm also using media player classic home cinema which supports hevc 10bit without any problem.(with dxva or cuvid)
windows 7 64bit
kodi 17.3
msi geforce gtc1060 6GB(supports hevc 10bit decoding and encoding)
intel core2 quad cpu Q9650
kind regards
alr47
Using Kodi 17.3, Windows 10 and a Nvidia GT1030, and 4K 8/10bit hw acceleration works just fine.
Look at the player info and look at the differences
video 1 :
videodecoder : ff-hevc(SW)
pixelformat : yuv420p10le
deinterlace method : yadif=1:-1:1
video stream : 3840x2160px, 1.78 AR, 23.976 FPS
mediainfo : main [email protected]@high 10bit
chromasubsampling/string: 4:2:0(type2)
BT2020
not working with hw acceleration
video 2 :
videodecoder : ff-hevc-d3d11va (HW)
pixelformat : d3d11va_vld
deinterlace method : unknown
media info : main@L5@high 8bit
BT709
working with hw accelaration
Windows 7 -limitation, check this out:
http://forum.kodi.tv/showthread.php?tid=...pid2170078
