Full Version: Prefetch next Subscription depends on "all channels" instead of the selected one
Hi there,
i am using the following Versions with different Hardware:
KODI 17.3 (also LibreELEC 8.0.2)
HTS Tvheadend 4.2.3-19
Tvheadend HTSP Client 3.4.24.1 ("Welcomed client software: Kodi Media Center (HTSPv25)" from TVHeadends log)
The Number of Subscritions is set to "2" inside the configuration of the plugin.
I noticed, that always the next channel of the category "All Channels" is prefetched.
If you use another user defined Channel Set, the prefetch leads to delays, because the Client preloads the wrong channel.
Example:
The "all channel" set of the tvheadend server has the following order of the tv-stations:
TV 1
TV 2
TV 3
TV 4
The user defined channel set just includes three of them:
TV 1
TV 2
TV 4
If you change the channel from TV 1 to TV 2 the plugin prefetches TV 3 instead of TV 4 which makes no sense in this case, because TV 3 is not listed in this channel set.
Nobody else with this behaviour?
