I have installed Kodi v17.3 "Krypton" but appenetee the launch opens a black window for two seconds and does not start. Somebody can help me thank you
that is................
Sorry but i'm not very good with linux ....... can you explain it better?
thank you
did you click and READ the link above?
You are actually running kodi 18 alpha and I'm having the same issue.
Crashlog
Sorry can't get a debug as I can't start kodi.
@lefty420:
Line 12 in your crashlog tells you why that crashlog isn't as helpful as you might think
Install gdb
@sartano:
Line 63 in your logfile tells why yours is completely useless
14:37:42.372 T:139723482962304 NOTICE: Disabled debug logging due to GUI setting. Level 0.
Enable debug logging please and probably try to catch a crashlog, too. Make sure gdb is intalled
Gdb is installed
Even if I do not know what it is and how it is used!
A further question: how do I install version 17.3 or a stable version?
Entering the following commands in the terminal:
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install kodi
I install kodi 18 alpha!!!!!
thank you
sartano might be, that gdb is installed on your system. But then you didn't provide a 'crashlog' yet. Provide that please
For you other question.... i guess you still have a kodi nightly ppa installed.you could do the following on the commandline:
apt-cache policy kodi | pastebinit
That will show us where the actually installed kodi version comes from. As a first guess, i think that you have the team-xmbc/xmbc-nightly ppa installed.
If that's the case, do:
sudo apt-get purge kodi kodi.bin
sudo apt-add-repository --remove ppa:team-xbmc/xmbc-nightly
sudo apt-add-repository ppa:team-xbmc/ppa
sudo apt-get update
I can not use gdb !!!!
I'm sorry.
I tried to run your code but I always install the version kodi 18 alpha.
I do not understand
thank you
