2017-07-23, 18:05
Anyone have any experience using mariadb (10.2.6-MariaDB-10.2.6+maria~jessie) in docker with Kodi?
I just made the switch from a MySQL server running on bare metal (which worked fine). Sometimes it works perfectly, but I often have the problem that the clients cannot connect. In the db logs, I see hundreds of lines of:
And so on. I googled this, came across the tip to increase the max_packet_size, which I did, but to no avail.
Just wondering if anyone else has this setup working - perhaps I'm doing something stupid here, or perhaps Kodi isn't compatible with mariadb.
db_1 | 2017-07-23 16:00:47 140643086067456 [Warning] Aborted connection 1262 to db: 'MyMusic60' user: 'xbmc' host: '192.168.92.25' (Got an error reading communication packets)
db_1 | 2017-07-23 16:00:47 140643086268160 [Warning] Aborted connection 1263 to db: 'MyMusic60' user: 'xbmc' host: '192.168.92.25' (Got an error reading communication packets)
db_1 | 2017-07-23 16:00:47 140643086268160 [Warning] Aborted connection 1264 to db: 'MyMusic60' user: 'xbmc' host: '192.168.92.25' (Got an error reading communication packets)
db_1 | 2017-07-23 16:00:47 140643086268160 [Warning] Aborted connection 1265 to db: 'MyMusic60' user: 'xbmc' host: '192.168.92.25' (Got an error reading communication packets)
db_1 | 2017-07-23 16:00:47 140643200857856 [Warning] Aborted connection 1266 to db: 'MyMusic60' user: 'xbmc' host: '192.168.92.25' (Got an error reading communication packets)
