Full Version: Hardware-accelerated video blanks after a few seconds
I am using the nightly builds, and about a week ago, Kodi stopped being able to play hardware-accelerated video (so anything hidef using VDPAU). Video starts fine, but after 10-30 second, the video goes black (audio keeps playing). Kodi has no problem with non-hardware accelerated video, and other media players on the same setup have no problem with VDPAU-using videos (I've tried mplayer and VLC).
Checking the debug log, this message appears when the video blanks out:
09:46:01.658 T:2964953152   ERROR: CVdpauTexture::MapRGB error register output surface: 1285
This is absolutely consistent (except for the timestamp). There is nothing else in the log either before or after. I do have the entire debug log if anyone thinks that'll help
EDIT: Full debug log here: https://pastebin.com/SHx5sAVZ
The system is running Ubuntu Linux 16.04.02, video card is a built-in nVidia ION, running Kodi nightly builds, which are currently 18.0.
Anyone have any ideas?
I have similar Problems, but only with Nvidia graphics, and only when jumping in the video or
changing the audio channel. But when the video runs, and I don't do anything, it runs without
problems. The problem appears not every time, but most times.
The log shows:
CVdpauTexture::MapRGB error register output surface: 1282
I am using a self built Master Branch of Kodi under Debian Buster.
Issue is known. Last nvidia card a developer has got broken - if it can be reproduced with AMD + vdpau then there is a chance it can be fixed prior to v18 - else: does not look good.
But I am using the Nvidia  legacy-340xx drivers under Debian. Newer drivers do not work with the ION graphics.
No problem with the Intel Skylake graphics (same kodi build).
(2018-05-21, 14:35)mase76 Wrote: [ -> ]But I am using the Nvidia  legacy-340xx drivers under Debian. Newer drivers do not work with the ION graphics.
 No "but" involved. VDPAU is broken ... not related to the driver.
Edit: Turn off VDPAU and it will work. Skylake uses VAAPI.
