Full Version: Series: episode per folder or all in one
My tmm only find an episode if it is in its own folder.
Multiple episodes in the same folder are not found.
Is this a fixed rule? I couldn't find a setting for that.
And sometimes the scenario is mixed. Some episodes in their own folder and some of them are together in one folder. This for the same series/sesson.
Can tmm handle this by itself?
Should be all fine.
Can you give us some directory listing, how your files are named?
Or maybe a screenshot?
Or the logfile?
$ ls -R1
The.Series.S07E03.HDTV.x264-FLEET[PRiME]/
The.Series.S07E04.HDTV.x264-FLEET[rarbg]/
The.Series.S07E06.HDTV.x264-DEFiNE[rarbg]/
The.Series.S07E07.HDTV.x264-FLEET[rarbg]/
The.Series.S07E16.PROPER.720p.HDTV/
The.Series.S07E09/
The.Series.S07E10/
The.Series.S07E11/
The.Series.S07E12/
The.Series.S07E13/
The.Series.S07E14/
The.Series.S07E01.HDTV.x264-KILLERS[eztv].mkv
The.Series.S07E01.HDTV.x264-KILLERS[eztv].srt
The.Series.S07E02.HDTV.x264-FLEET[eztv].mkv
The.Series.S07E05.HDTV.Subtitulado.ESP.SC.avi
The.Series.S07E08.HDTV.x264-FLEET[eztv].mkv
./The.Series.S07E03.HDTV.x264-FLEET[PRiME]:
The.Series.S07E03.HDTV.x264-FLEET[PRiME].mkv
./The.Series.S07E04.HDTV.x264-FLEET[rarbg]:
The.Series.S07E04.HDTV.x264-FLEET.mkv
./The.Series.S07E06.HDTV.x264-DEFiNE[rarbg]:
The.Series.S07E06.HDTV.x264-DEFiNE.mkv
./The.Series.S07E07.HDTV.x264-FLEET[rarbg]:
The.Series.S07E07.HDTV.x264-FLEET.mkv
./The.Series.S07E16.PROPER.720p.HDTV:
The.Series.S07E16.PROPER.720p.HDTV.mkv
./The.Series.S07E09:
The.Series.S07E09.mkv
./The.Series.S07E10:
The.Series.S07E10.mp4
./The.Series.S07E11:
The.Series.S07E11.mkv
./The.Series.S07E12:
The.Series.S07E12.mp4
./The.Series.S07E13:
The.Series.S07E13.HDTV.x264.mp4
./The.Series.S07E14:
The.Series.S07E14.mp4
This files are nto recognized by tmm - maybe because they don't have their own folder.
In which directory are the 5 missing files?
Are they're in the datasource root?
(can't see the whole structure with your examples - wanna PN some logs?)
Because then it does not work - for series, you MUST have at least a series folder in datasource root, and then we don't care about structure...
(you should not add a series directory directly as datasource)
The point with the "root" folder was the solution. Thank you very much.
