Full Version: Certification format
I'm using TNN in Germany and I want to set the "Certification format" (in Germany FSK) to only the age, for example "12" or "16", but the shortest possibility is "FSK 12". Is it possible to define in a settings file?
Regards
Michael
No.
When there's only "12" written to the NFO file, how should any program know, what rating system used?!? (to display the correct image)
What do you really want to archieve?
Why do you want this?
Ok, I was not aware, that other programs need the information for the rating system.
I want to achieve a more cleaner view on the info-screen. But your reply helps me, thanx.
