Want to know is there a way disable default splash screen with Kodi logo from within the skin or using python? I know I can delete it. But I am lazy and don't want too.
Can be closed apparently in wrong section of the forum
I know I can do it from advancesettings I wanted to do it from within the skin. Or make a add-on using jsn if need be.
I am just not sure how to word the jsn if I used a script
Also I know I can use skin helper to disable some skin settings as well... But once again I just wanted help on the wording... To use it as the is not much on the name of the actual setting..
Also Klojum if you had read the post I asked from Within the skin.. and if I am planning on using the skin XML or python don't you think that is being lazy as well. Kodi team members like you with sarcastic answers are what give u all bad names around here you didn't have to answer at all.
You could write a python script that deletes the file (or better renames it so that the script can also revert it back).
Yea i was hoping it would be a off on json, or python line but it looks like python to a xml phaser and add delete line from the advance settings. Though maybe skinhelper would work if someone knew or knew how to fine the name of the setting.
