that I used to create a basis.
It is said that that tool has malware included or delivers false positives. I don't want to run any risks so I exported the registry settings and saved that as well. This is it:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HidIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da]
"ReportMappingTable"=hex:\
00,00,00,00,04,00,27,\ ; 0
01,00,00,00,04,00,1e,\ ; 1
02,00,00,00,04,00,1f,\ ; 2
03,00,00,00,04,00,20,\ ; 3
04,00,00,00,04,00,21,\ ; 4
05,00,00,00,04,00,22,\ ; 5
06,00,00,00,04,00,23,\ ; 6
07,00,00,00,04,00,24,\ ; 7
08,00,00,00,04,00,25,\ ; 8
09,00,00,00,04,00,26,\ ; 9
0a,00,00,00,04,00,29,\ ; Clear - sends escape
0b,00,00,00,04,00,28,\ ; Enter - sends return
0c,00,00,00,03,82,00,\ ; Power - left at Windows default, use "04,04,3d" to send alt-F4
0d,00,00,00,04,03,1a,\ ; Windows - sends ctrl-shift-W
0e,00,00,00,04,00,41,\ ; Mute - was "01,e2,00" sends F8
0f,00,00,00,04,00,06,\ ; Info - was "01,09,02" sends ctrl-D (standaard 04,01,07, stuurt met huidige code een c)
10,00,00,00,01,e9,00,\ ; vol up - was "01,e9,00" sends F10 in MCRemote standaard 04,00,43
11,00,00,00,01,ea,00,\ ; vol down - was "01,ea,00" sends F9 in MCRemote standaard 04,00,42
12,00,00,00,01,9c,00,\ ; chan up - was "01,9c,00" sends PgUp in MCRemote standaard 04,00,4B
13,00,00,00,01,9d,00,\ ; chan down - was "01,9d,00" sends PgDn in MCRemote standaard 04,00,4E
14,00,00,00,01,b3,00,\ ; ff - was "01,b3,00" sends ctrl-shift-F in MCRemote standaard 04,03,09
15,00,00,00,01,b4,00,\ ; rew - was "01,b4,00" sends ctrl-shift-B in MCRemote standaard 04,03,05
16,00,00,00,01,b0,00,\ ; play - was "01,b0,00" sends ctrl-shift-P in MCRemote standaard 04,03,13
17,00,00,00,01,b2,00,\ ; record - was "01,b2,00" sends ctrl-R in MCRemote standaard 04,01,15
18,00,00,00,01,b1,00,\ ; pause - was "01,b1,00" sends ctrl-P in MCRemote standaard 04,01,13
19,00,00,00,01,b7,00,\ ; stop - was "01,b7,00" sends ctrl-shift-S in MCRemote standaard 04,03,16
1a,00,00,00,01,b5,00,\ ; next - was "01,b5,00" sends ctrl-F in MCRemote standaard 04,01,09
1b,00,00,00,01,b6,00,\ ; prev - was "01,b6,00" sends ctrl-B in MCRemote standaard 04,01,05
1c,00,00,00,04,03,20,\ ; # - sends ctrl-shift-3
1d,00,00,00,04,03,25,\ ; * - sends strl-shift-8
1e,00,00,00,04,00,52,\ ; up
1f,00,00,00,04,00,51,\ ; down
20,00,00,00,04,00,50,\ ; left
21,00,00,00,04,00,4f,\ ; right
22,00,00,00,04,00,28,\ ; OK (return)
23,00,00,00,01,24,02,\ ; back - was "01,24,02" sends Backspace in MCRemote standaard 04,00,2a
24,00,00,00,04,01,08,\ ; DVD menu - sends ctrl-shift-M in MCRemote standaard 04,03,10 nu naar Movies laten gaan dus ctrl-E sturen
25,00,00,00,04,03,17,\ ; Live TV - sends ctrl-shift-T
26,00,00,00,04,01,0a,\ ; Guide - was "01,8d,00" sends ctrl-G in MCRemote standaard
27,00,00,00,04,05,17,\ ; Unidentified top left button on Asrock remote - configured as ctrl-alt-T
47,00,00,00,04,01,10,\ ; Music - sends ctrl-M
48,00,00,00,04,01,12,\ ; Recorded TV - sends ctrl-O
49,00,00,00,04,01,0C,\ ; Pictures - sends ctrl-I
4A,00,00,00,04,01,08,\ ; Movies - sends ctrl-E
4E,00,00,00,04,05,13,\ ; HP remote: Print button - sends ctrl-alt-P
50,00,00,00,04,01,04,\ ; Radio - sends ctrl-A
5A,00,00,00,04,01,17,\ ; Teletext - sends ctrl-T
5B,00,00,00,04,05,1e,\ ; Red - sends ctrl-alt-1 in MCRemote standaard 04,05,1e
5C,00,00,00,04,01,10,\ ; Green - sends ctrl-alt-2 in MCRemote standaard 04,05,1f opent nu muziek
5D,00,00,00,04,01,0C,\ ; Yellow - sends ctrl-alt-3 in MCRemote standaard 04,05,20 opent nu afbeeldingen
5E,00,00,00,04,05,21 ; Blue - sends ctrl-alt-4 in MCRemote standaard 04,05,21
The Green Button (WMC button) goes to start.
The "i" button shows info, basically pulls up a right mouse click and allows for deletion easily
The rest is mapped as it was in WMC. Live TV, Guide etc.
