I installed ESPN and activated it but the activation says ok but won't hold more than a couple minutes.
I have Cox Internet and the IP address is different in my Minix box, could this be it.
Is your local IP address on the device different (which is normal, something like 192.168.XX.XX) or are you saying your internet IP is different in your Minix? If the latter, then that is something you might have changed yourself (like via VPN), so I would suggest revert to Cox assigned IP and try it out.
The Minix is like you said 192.168.xx.xx but my computer is different.
Any help still can't stay connected on Minix u1, it works for a few minutes and then says deactivated. Works OK on windows.
Do I have to sync my computer to Minix?
I still can't figure this out. I know Cox channels won't work on computer away from your internet
No problem with NBC Sports it works okay.
