How Do Stop Next TV Episode from Starting Automatically. If I don't stop the one I'm viewing, it starts the next right away. How do I turn this off.
I'm running Kodi 17.3 with amber skin.
That's due to you using an add-on that does this automatically. Probably "next up" but as you installed it and turned it on, you'll know.
There's also
settings > player settings > video > actions > play next video automatically
which should be set to off if you don't want it to.
(2017-07-30, 03:37)nickr Wrote: [ -> ]That's due to you using an add-on that does this automatically. Probably "next up" but as you installed it and turned it on, you'll know.
I found a addon called TV-Next, Uninstalling it didn't help. Any other suggestions. I only get this happening with TV Episodes.
If you've not got the setting above in my other post set, then provide us with a debug enabled
debug log (wiki) via PasteBin.com and we'll see from the addons list what else may be causing it.
