2017-07-30, 23:51
I enabled "Enable debug logging" and sent you the kodi.log file. What other file do you want? Kodi wiki is down so sorry if I shoud know this...
(2017-07-30, 23:41)goodton Wrote: [ -> ]I assume that this stuttering is not happening all the time in your sample file but just during the scenes where the bitrate is higher? I have experienced same kind of issues and although also my setup (windows 10, i7-5775C, NVidia 1050Ti) is more than capable of HW-decoding and playing 4K HEVC Main10-files, 32-bit Kodi 17.x can still struggle. This is not related to HDR, perhaps some strange timing issue as CPU/GPU are not struggling at all. If High Performance -power plan is toggled on in Windows-settings, this issue mostly disappears in my case. The main thing here is that the CPU is not dynamically changing the clock speed, by default in High Performance -mode CPU is running in full speed.
Other option is to use latest 64-bit Kodi 18-nighlies, those will handle these files much better. Third option would be the 32-bit DSPlayer-build of Kodi 17.3 with latest MadVR, In that case you will also have the possibility to send the HDR-metadata to your TV using the NVidia-API. Works great with no stuttering
(2017-07-31, 00:40)asagala Wrote: [ -> ](2017-07-30, 23:41)goodton Wrote: [ -> ]I assume that this stuttering is not happening all the time in your sample file but just during the scenes where the bitrate is higher? I have experienced same kind of issues and although also my setup (windows 10, i7-5775C, NVidia 1050Ti) is more than capable of HW-decoding and playing 4K HEVC Main10-files, 32-bit Kodi 17.x can still struggle. This is not related to HDR, perhaps some strange timing issue as CPU/GPU are not struggling at all. If High Performance -power plan is toggled on in Windows-settings, this issue mostly disappears in my case. The main thing here is that the CPU is not dynamically changing the clock speed, by default in High Performance -mode CPU is running in full speed.
Seems interesting. Can you point me in the right direction for the DSP PLayer build. Are you refering to this https://forum.kodi.tv/showthread.php?tid=223175?
(2017-07-31, 01:26)brazen1 Wrote: [ -> ]I'm no debug log expert but right off the bat I suggest you try setting your GPU desktop to 2160p instead of 1080p. Same with the Kodi GUI. I think by setting them to 1080p instead of 2160p you are forcing the Kodi software player to upscale instead of the display logic which would explain the stuttering as it fights to do a job the display would do easier and better. The file you are trying to play is crap too. Test with the Kodi wiki samples which as luck has it is down for maintenance for now.
(2017-07-31, 17:23)brazen1 Wrote: [ -> ]Hi Fritsch.
I'm trying to wrap my head around this but my results are different? Here is what I have learned:
Setting the windows desktop at 1080p vs 2160p has no affect on Kodi resolution output and it shouldn't. All depends exclusively what Kodi is set at. Windows desktop looks bad at 1080p. 2160p is much better.
Good means sharp, precise, clear, as intended, etc.
Bad means grainy, fuzzy, not clear, low res, jagged, etc.
Setting Kodi at 2160p:
Kodi GUI displays very good. Display reports 2160p.
1080p video displays very good. Display reports 2160p.
2160p video displays very good. Display reports 2160p.
Setting Kodi at 1080p:
Kodi GUI displays bad. Display reports 1080p.
1080p video displays bad. Display reports 1080p.
Fwiw, using Samsung C8000 (1080p display) Kodi GUI, at 1080p of course, looks good. 1080p titles look good.
"When Kodi outputs to 1080p TV upscales."
According to your statement (which makes sense) my results show Kodi upscale is better than my TV logic. I don't think Kodi upscale is better than Samsung JS8500 (4k display)? Maybe it is? Your thoughts?
