Full Version: IR remote and video streaming not working
Hi all,
I've been running XBMC for two years, then OpenELEC for one year on a RaspberryPi model B, and I've been very satisfied. I grew tired of OpenELEC's read-only file system and unchangeable root password, so I decided to do a fresh Raspbian install and then Kodi 17 on top. However, I have a few problems:
1. My Philips TV infrared remote control. It worked out-of-the-box with XBMC and OpenELEC, and now it doesn't. It does say when it boots, that Pulse-Eight CEC adapter is installed and running, but the remote doesn't work.
2. When streaming tv (add-on "Danish Live TV") I only have sound - no picture. This worked fine on XBMC and OpenELEC.
Any suggestions?
Best regards,
Steen
For the 1st question:
Check the TV settings if CEC is correctly enabled. If all is correct, I guess you have to ask Raspbian for that issue. You could do a quick check with LibreELEC and see if CEC works there. If yes, then that is not a Kodi related problem, but maybe an OS related problem. So I guess the guys from Raspbian might know best.
For the 2nd question....
Contact the author:
https://github.com/xbmc-danish-addons/pl...dr.dk.live
https://tommy.winther.nu/wordpress/
