Full Version: [SOLVED] Position video at the top of the screen
Hi everyone,
for videos that are wider than the screen ratio,
--> is there an easy way to put these videos at the top of the screen, instead of verticaly centered ?
Meaning, there will be one big black border below the video, instead of two black borders at top and bottom.
Thank you ! Smile
Most hardware supports the Vertical Shift option in the Video settings of the Video OSD.
Set it to -1.00 and the display should be aligned to the top of the screen.
Wow, that was exactly what I was searching for !
I just didn't know it was there !
Thank you ! Smile
