Full Version: xbmc.Monitor().abortRequested()
I have an addon with a service, the service run while a user is logged in using this in the addon.xml
<extension point="xbmc.service" library="service.py" start="login">
The service should be running all the time while the user is logged into Kodi.
I was told to use the in my service loop
xbmc_monitor = xbmc.Monitor()
while not xbmc_monitor.abortRequested():
   <do servisy stuff here>
   xbmc_monitor.waitForAbort(1)
However, I have noticed that .abortRequested() can return true when an addon action is stopped, i.e. you call the addon to show a list if ListItems and as it is doing that you hit backspace, this cansels the addon call but triggers a global abort requested action which triggers the service monitor instance and the service also exists.
Should this be how monitor.abortRequested() works?
In a service should I be using a different abort requested mechanism?
I observed similar behavior and submitted a ticket to Kodi. My guess is it's a bug.
https://forum.kodi.tv/showthread.php?tid=317384
Sent from my SM-G935T
I found if I go back to my original way
if xbmc.abortRequested:
   <do service stuff>
then it works as intended.
(2017-07-31, 08:26)null_pointer Wrote: [ -> ]I found if I go back to my original way
   <do service stuff>
This isn't a loop unless you left something out Smile
while not xbmc.abortRequested:
   <do service stuff>
   xbmc.sleep(1000)
(2017-08-01, 00:05)null_pointer Wrote: [ -> ]
   <do service stuff>
   xbmc.sleep(1000)
Yeah your bypassing the problem area...Smile
I believe it's a bug with waitforabort.
PR11852, and fixed in Kodi 18.
Hasn't yet been backported to Kodi 17.
(2017-08-01, 03:51)Milhouse Wrote: [ -> ]PR11852, and fixed in Kodi 18.
Thanks for the heads up...
Is this going to be backported? It looks like the fix was added back in Mar, this might have even made the 17.3 build if it was backported back then.
PR12610.
