2017-07-31, 06:43
Hi Kodi
This error have been driving me nuts since I upgraded v16 - v17. I have finally fixed it but had to use my illustriousness skill. (i had to think, it hurt!)
I was so over the moon so I thought to create an account in the forum and post my "solution". The solution was actually simple but will skip to the relevant details.
Issue:
KODI does not progress from the splash screen.
My Kodi setup is as normal apart from advancedsettings has mysql (ofcourse).
kodi.log says:
ERROR: SQL: [MyVideos107] The table does not exist
Query: SELECT idVersion FROM version
ERROR: CJobWorker:rocess error processing job
The fix:
Duplicate the old MyVideos99 (or what ever MyVideosXX you have) to MyVideos107
Run your KODI again.
Steps:
on your mysql server
shell> mysqldump -u kodi -p MyVideos99 > bob.sql
shell> mysqladmin create MyVideos107 -u kodi -p
shell> mysql MyVideos107 < bob.sql -u kodi -p
I cannot explain why even though I the database is very small (1 entry). Hoping kodi specialist can perhaps explain.
Hope this helps
Moderators, please feel free to delete/correct my post.
Issue:
kodi.log says:
The fix:
Steps:
Hope this helps
