2017-07-31, 08:57
Hi All
Maybe somebody has a answer to my problem that i am having with volume settings between profiles.
First a break down.
I have 2 profiles.
1. Movies
2. Music
In my Music profile i have customized the Aeon Nox skin to only display Music menu, Movies are not accessible at all. My Movie profile however has access to both music and movies
I use 2 different audio output settings. Movies goes via my AVR and Music uses a usb-SPDIF converter to a dedicated Stereo system this gives me best of both world
I have created a keymap that allows me to swap profiles seamlessly.
The problem that i have is that is my Movie profile is set to 100% always as the avr controls the volume, if i flip to Music I use the kodi volume as i am not using a preamp. If the volume is set to mute ( It displays the speaker with the x through it at the top right ) and press play it instantly goes to 100% until i press the volume button either up or down, then it will use the current setting on that profile.
I have the same issue if i go back to Movie profile. The profile is set to 100% but volume is soft ( same level as the audio profile ) until i press volume + or - on a keyboard, then it goes to 100% setting of that profile
Can anybody shed some light as to why it does this?
First a break down.
I have 2 profiles.
1. Movies
2. Music
