2017-07-31, 18:27
once I thought this would not be a problem at all, but as I found out, it unfortunately is. First let me explain: assume you have a network drive, and there is a videofile still being written, but you already want to watch the first minutes of it, then my problem is as follow:
Kodi only notices the overall duration of the video at the very moment when the file is being clicked on to be played. But: the file is getting bigger and bigger in the background. When you only play the file, it's not a problem, because when Kodi reaches the end of the file, it notices that there is more to play, and plays it. fine.
However, if you fast forward or jump through the file, that information is not updated, and Kodi will come to the end after 10 minutes (at least it thinks so, even though the file has grown in the meantime), and stops the file, and doesn't even remember the progress, i.e. it starts from the beginning when you replay it.
To clarify what I mean: let's assume I start my file with 10 minutes being written. Then, there is some part of the file I would like to skip after 5 minutes, then the actual duration of that file is not 10 minutes anymore, but 15 minutes. But I cannot skip beyond 10 minutes, because Kodi will break playback.
Very very sad tath this is implemented that way. What am I doing wrong, or is this actually a kodi bug?
