2017-08-01, 20:22
I have tried following the successful threads, but I have not been able to fox this issue. If anyone can take a look and try to help me out, I would greatly appreciate it. Here is my log dump. Thank you in advance!
17:33:35.890 T:140735166259200 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:33:35.890 T:140735166259200 NOTICE: -----------------------------------------------------------------------
17:33:35.890 T:140735166259200 NOTICE: Starting Kodi (17.1 Git:20170320-fc1619b). Platform: OS X x86 64-bit
17:33:35.890 T:140735166259200 NOTICE: Using Release Kodi x64 build
17:33:35.890 T:140735166259200 NOTICE: Kodi compiled Mar 20 2017 by Clang 6.0 (clang-600.0.56) for OS X x86 64-bit version 10.8.0 (1080)
17:33:35.890 T:140735166259200 NOTICE: Running on Apple Inc. MacBookAir7,1 with OS X 10.11.6, kernel: Darwin x86 64-bit version 15.6.0
17:33:35.890 T:140735166259200 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
17:33:35.890 T:140735166259200 NOTICE: Host CPU: Intel® Core i5-5250U CPU @ 1.60GHz, 4 cores available
17:33:35.890 T:140735166259200 NOTICE: special://xbmc/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
17:33:35.890 T:140735166259200 NOTICE: special://xbmcbin/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
17:33:35.890 T:140735166259200 NOTICE: special://xbmcbinaddons/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi/addons
17:33:35.890 T:140735166259200 NOTICE: special://masterprofile/ is mapped to: /Users/Aidanrose/Library/Application Support/Kodi/userdata
17:33:35.890 T:140735166259200 NOTICE: special://envhome/ is mapped to: /Users/Aidanrose
17:33:35.890 T:140735166259200 NOTICE: special://home/ is mapped to: /Users/Aidanrose/Library/Application Support/Kodi
17:33:35.890 T:140735166259200 NOTICE: special://temp/ is mapped to: /Users/Aidanrose/.kodi/temp
17:33:35.890 T:140735166259200 NOTICE: special://logpath/ is mapped to: /Users/Aidanrose/Library/Logs
17:33:35.890 T:140735166259200 NOTICE: special://frameworks/ is mapped to: /Applications/Kodi.app/Contents/Libraries
17:33:35.890 T:140735166259200 NOTICE: The executable running is: /Applications/Kodi.app/Contents/MacOS/Kodi
17:33:35.890 T:140735166259200 NOTICE: Local hostname: Aidans-Air.fios-router.home
17:33:35.890 T:140735166259200 NOTICE: Log File is located: /Users/Aidanrose/Library/Logs//kodi.log
17:33:35.890 T:140735166259200 NOTICE: load settings...
17:33:35.897 T:140735166259200 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
17:33:35.897 T:140735166259200 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
17:33:35.917 T:140735166259200 NOTICE: Found 1 Lists of Devices
17:33:35.917 T:140735166259200 NOTICE: Enumerated DARWINOSX devices:
17:33:35.917 T:140735166259200 NOTICE: Device 1
17:33:35.917 T:140735166259200 NOTICE: m_deviceName : default
17:33:35.917 T:140735166259200 NOTICE: m_displayName : Default
17:33:35.917 T:140735166259200 NOTICE: m_displayNameExtra: Built-in Output
17:33:35.917 T:140735166259200 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:33:35.917 T:140735166259200 NOTICE: m_channels : FL,FR
17:33:35.917 T:140735166259200 NOTICE: m_sampleRates : 96000,88200,48000,44100
17:33:35.917 T:140735166259200 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_S16NE
17:33:35.917 T:140735166259200 NOTICE: m_streamTypes : No passthrough capabilities
17:33:35.917 T:140735166259200 NOTICE: Device 2
17:33:35.917 T:140735166259200 NOTICE: m_deviceName : Built-in Outputtream0
17:33:35.917 T:140735166259200 NOTICE: m_displayName : Built-in Output
17:33:35.917 T:140735166259200 NOTICE: m_displayNameExtra: Internal Speakers
17:33:35.920 T:140735166259200 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
17:33:35.920 T:140735166259200 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:33:35.920 T:140735166259200 NOTICE: Default Video Player: VideoPlayer
17:33:35.920 T:140735166259200 NOTICE: Default Audio Player: paplayer
17:33:35.920 T:140735166259200 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:33:35.920 T:140735166259200 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:33:35.920 T:140735166259200 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:33:35.920 T:140735166259200 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:33:35.921 T:140735166259200 NOTICE: Loaded playercorefactory configuration
17:33:35.921 T:140735166259200 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:33:35.921 T:140735166259200 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:33:35.925 T:140735166259200 NOTICE: Attempting to update the database Addons27 from version 20 to 27
17:33:35.926 T:140735166259200 ERROR: SQL: [Addons27.db] SQL error or missing database
Query: CREATE TABLE installed (id INTEGER PRIMARY KEY, addonID TEXT UNIQUE, enabled BOOLEAN, installDate TEXT, lastUpdated TEXT, lastUsed TEXT)
17:33:35.926 T:140735166259200 ERROR: Exception updating database Addons27 from version 20 to 27
17:33:35.926 T:140735166259200 ERROR: Error updating database Addons27 from version 20 to 27
17:33:35.926 T:140735166259200 NOTICE: Old database found - updating from version 20 to 27
17:33:35.939 T:140735166259200 NOTICE: Attempting to update the database Addons27 from version 20 to 27
17:33:35.978 T:140735166259200 ERROR: SQL: [Addons27.db] The database disk image is malformed
Query: DELETE FROM addon
17:33:35.978 T:140735166259200 ERROR: Exception updating database Addons27 from version 20 to 27
