Full Version: Can't play BDMV blu ray rips or .iso
Using DSPlayer with Emby Kodi addon. I've disabled HTTP over SMB and am using the "Native" (i.e., direct paths) setting. The player fails to open either .isos or full blu ray rips in /BDMV folder structure. Can anyone help me out with the log file below? Not sure what is going wrong.
08:23:26.858 T:9704 ERROR: CBlurayDirectory::GetDirectory - failed to open smb://Movies/Family/The.Smurfs.2
08:23:26.858 T:9440 ERROR: XFILE::CDirectory::GetDirectory - Error getting bluray://smb%3a%2f%2fMovies%2fFamily%2fThe.Smurfs.2/root
08:23:26.858 T:9440 ERROR: CGUIWindowVideoBase::ShowPlaySelection - Failed to get play directory for bluray://smb%3a%2f%2fMovies%2fFamily%2fThe.Smurfs.2%2f/root
08:23:26.872 T:9440 NOTICE: CDSPlayer::OpenFile - DSPlayer: Opening: smb://Movies/Family/The.Smurfs.2/BDMV/index.bdmv
08:23:26.873 T:9440 NOTICE: CDSPlayer::OpenFileInternal - DSPlayer: Opening: smb://Movies/Family/The.Smurfs.2/BDMV/index.bdmv
08:23:26.874 T:1316 NOTICE: CDSPlayer:Tonguerocess - Creating DS Graph
08:23:26.876 T:9212 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig_internal.xml (filters configuration).
08:23:26.879 T:9212 NOTICE: Loading filter core factory settings from special://masterprofile/dsplayer/filtersconfig.xml (filters configuration).
08:23:26.879 T:9212 NOTICE: special://masterprofile/dsplayer/filtersconfig.xml does not exist. Skipping.
08:23:26.879 T:9212 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig.xml (filters configuration).
08:23:26.886 T:9212 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/mediasconfig_internal.xml (medias configuration).
08:23:26.887 T:9212 NOTICE: Successfully loaded rules
08:23:26.890 T:9212 NOTICE: CFGLoader::InsertAudioRenderer Successfully added internal sanear audio renderer to the graph
08:23:26.912 T:1204 NOTICE: EMBY.kodimonitor -> Method: Playlist.OnClear Data: {"playlistid":1}
08:23:26.947 T:9212 NOTICE: CFGLoader::InsertFilter Successfully added "(i) LAV Splitter Source" to the graph
08:23:26.953 T:9212 ERROR: CFGLoader::InsertSourceFilter Failed to load file in the splitter/source
08:23:26.953 T:9212 ERROR: CFGLoader::LoadFilterRules Failed to insert the source filter
08:23:26.953 T:9212 ERROR: CFGManager::RenderFileXbmc Failed to load filters rules
08:23:26.953 T:9212 NOTICE: thread end: CDSGraphThread::OnExit()
08:23:26.953 T:1316 ERROR: CDSPlayer:Tonguerocess - Failed creating DS Graph
08:23:26.953 T:9440 ERROR: Playlist Player: skipping unplayable item: 0, path [smb://Movies/Family/The.Smurfs.2/BDMV/index.bdmv
Post a complete Debug log (wiki).
My bad. Here you go.
https://pastebin.com/wBXaGgHd
Please ask in the dsplayer thread. Not a Kodi issue.
I uninstalled DSPlayer Kodi and just installed stock Kodi with same result (movie wouldn't load). I'll post that log when I get home I guess.
Fresh install of standard Kodi install. Mounted directly (no emby addon).
https://pastebin.com/U05axspG
Also, for what it's worth, I moved the folder to my local C: drive and still had the same errors (though a different path, obviously)
More info. It appears that the BDMV structure works for regular blu ray rips, but not UHD blu ray rips, which this Smurfs 2 is. Any thoughts on how to fix that?
@lexiconman
I don't understand your motive behind editing your posts to blank them. I have re-instated all your posts.
I can see that as extremely selfish behaviour, that once you obtained your answer, you felt no-one should benefit from it... Especially as you have "figured it out", but don't want to post the solution.
Obviously you don't need further help, so I have locked this thread. I have applied a warning to your account... That way we are all reminded of your behaviour.
