2017-08-05, 07:21
It seems a couple of settings are missing in Kodi 17.3 + 18 for the Pulse Eight CEC adapter in Linux (Ubuntu 16.04 x64) - the options are present in Windows installer 17.3. The options that are missing are "HDMI port number" and "Connected to HDMI device". No matter what I try Kodi Linux switches my AVR to input 2, when it should be on input 3. Input from the TV remote works though. Everything works as should in Win 10 + Kodi 17.3 on the same PC.
I have tried:
-Updating to a test version of libcec from the Pulse Eight PPA - v4.0.2.3
-Ensure I'm using the latest firmware - v7
-Manually edit the settings for "cec_hdmi_port" and "connected_device" in ~.kodi/userdata/peripheral_data/usb_2548_1002_CEC_Adapter.xml - settings are ignored
-Edited /usr/share/kodi/system/peripherals.xml - I can make the options appear by deleting the line "<setting key="physical_address" type="string" label="36021" value="0" order$", but even after getting the notification that the adapters settings have been updated and a kodi restart, the HDMI port setting is back on 1, though this time it switches my AVR to another input. When re-entering the CEC adapter settings the options are back on what they original were.
-Edited the default values in /usr/share/kodi/system/peripherals.xml - no effect.
-Compiling libcec from git - getting a error
-Copying usb_2548_1002_CEC_Adapter.xml and peripherals.xml from the working windows install - no effect
-Updating to Kodi 18 - same issue.
-Found a OE forum thread about the same issue - no solution in that thread.
-Reinstalling Kodi 17.3 from the stable PPA - same issue.
-Deleting my ~/.kodi directory and trying a fresh setup - same issue.
-Running "sudo chmod 777 /dev/ttyACM0" - no effect.
-Unplugging and re-plugging in the adapter while Kodi is running - dis/reconnected is detected by Kodi but has no effect.
-Probably missed something else I tried - this is all from memory.
Kodi 17.3 debug log file of me navigating to the CEC adapter options (with no modifications to peripherals.xml)
Anyone have any idea what the issue could be? I'm stumped!
I have tried:
