When i start OSXBMC 1.6 the CPU usage is very high even when it's idle is always around 50%.
Mij MBP C2D 2.33 runs hot this way, and it sucks empty the battery empty in no time. Anyone else has this behavior?
i heard turning on Vsync in options solves this.
The 'problem' is in idle the GUI is being ran at an FPS as high as possible so it max out the CPU. Not really a problem though but when you turn on Vsync in options it should thake less CPU i think
tnx f4 replying
I can't find that option, only Screen/vertical blanc sync, it was already set to "always enabled"
After some minutes running OSXBMC the Cpu usage drops a bit, but it's always above 10% and without a reason it's raising for periods to 50%
I've verified that this is a bug even with vertical sync enabled.
On my macbook(2Gig 2gig ram gma950 skin PM3)when doing nothing I always have 13-25% cpu?! When I hide xbmc(running 480p)to the dock CPU load increase from 15 to 30%?!(doing nothing)
Clean install of xbmc 0.1.7
Known issue, hopefully fixed in the next release (high CPU when hidden).
-elan
still high cpu usage when hidden running 0.4.0
yes, unfortunately it still is high when minimized (avg40%). After minutes the CPU temp goes up to 71 Celsius, and the fans kick in!
The bug should be fixed in 0.4.1, when it's released.
elan Wrote:The bug should be fixed in 0.4.1, when it's released.
Too bad it still isn't fixed
If there's not a Ticket for this, please create one.
Thanks,
-elan
