I added some Spaceflight Iso's to kodi but for some reason, atm 3 of them do not show up in my library. I have them labelled the same way as I do the ones that do work but for some reason if I click on the source folder in videos/file. I can see those videos in there, but when I add them to a submenu under spaceflight they do not show up when I click on the link. I checked my log and every time it shows the movie name with an error "Information not found, item not added to library"
We need more information - you say movie name but do you mean the TV show? How are they labelled?
How can we help you if you won't share the information. You know what the movie names are... we don't. You are looking at the logs... we aren't. What help do you want??
Ive set the movies up like this
G:\SPACEFLIGHT\Apollo 8 Leaving the Cradle\Apollo 8 Leaving the Cradle Disc 1
G:\SPACEFLIGHT\Apollo 8 Leaving the Cradle\Apollo 8 Leaving the Cradle Disc 2
G:\SPACEFLIGHT\Apollo 8 Leaving the Cradle\Apollo 8 Leaving the Cradle Disc 3
G:\SPACEFLIGHT\Apollo 13 The Real Story\Apollo 13 The Real Story Disc 1
G:\SPACEFLIGHT\Apollo 13 The Real Story\Apollo 13 The Real Story Disc 2
G:\SPACEFLIGHT\Apollo 13 The Real Story\Apollo 13 The Real Story Disc 3
G:\SPACEFLIGHT\Apollo 15 Man Must Explore\Apollo 15 Man Must Explore Disc 1
G:\SPACEFLIGHT\Apollo 15 Man Must Explore\Apollo 15 Man Must Explore Disc 2
G:\SPACEFLIGHT\Apollo 15 Man Must Explore\Apollo 15 Man Must Explore Disc 3
G:\SPACEFLIGHT\Apollo 15 Man Must Explore\Apollo 15 Man Must Explore Disc 4
G:\SPACEFLIGHT\Apollo 15 Man Must Explore\Apollo 15 Man Must Explore Disc 5
G:\SPACEFLIGHT\Apollo 15 Man Must Explore\Apollo 15 Man Must Explore Disc 6
My apologies for not leaving more information. I was still at it trying to figure it out when I posted. I did include the years originally when I made the file folders for each seperate set but removed them for those 3 just in case the dates online weren't accurate. When I scanned the library I see their names but doesn't look like Kodi scans them. And when I go to my Spaceflight menu item, these 3 do not show up. I've checked the log and it will show only these 3 having no information found and due to that, they we're not added to the library. Ive done the other sets exactly the same, and they worked just fine. They showed up in the library. Not sure how to add the log file to here or where to find it besides viewing in kodi. Thank you
1) Apollo 8 Leaving the Cradle is listed as a TV series
https://thetvdb.com/?id=271571&tab=series
2) Apollo 13 The Real Story
http://www.imdb.com/title/tt2829778/ is listed as a movie series.
3) Apollo 15: Man Must Explore [Import] is listed as an import [unavailable] on Amazon's web site.
All three can be worked into your library, handled in slightly different ways.
The first case should be a straight TV scraper, but if you want to include them as individual movies
Custom video entries (wiki) you'll have to make custom metadata for each listing. The second in the Imdb, using the universal scraper will make fast work of this one. You'll need to set stacking in settings and rename each as per stacking rules.
http://kodi.wiki/view/Naming_video_files...tacking.29 Alternative would be to add them as a TV series in the TVdb and then everyone who has this set will enjoy your listings. The third is definitely going to be either a custom meta-data and hopefully, you'll add that to the TVdb as a series, or one of the movie database. Yup maintaining a great library can be difficult at times.
(2017-08-07, 01:23)PatK Wrote: [ -> ]1) Apollo 8 Leaving the Cradle is listed as a TV series https://thetvdb.com/?id=271571&tab=series
2) Apollo 13 The Real Story http://www.imdb.com/title/tt2829778/ is listed as a movie series.
The first case should be a straight TV scraper, but if you want to include them as individual movies Custom video entries (wiki) you'll have to make custom metadata for each listing. The second in the Imdb, using the universal scraper will make fast work of this one. You'll need to set stacking in settings and rename each as per stacking rules. http://kodi.wiki/view/Naming_video_files...tacking.29 Alternative would be to add them as a TV series in the TVdb and then everyone who has this set will enjoy your listings. The third is definitely going to be either a custom meta-data and hopefully, you'll add that to the TVdb as a series, or one of the movie database. Yup maintaining a great library can be difficult at times.
Thank you for checking the sets out
I will probably just set up the 13 set and 15 set on tvdb since the 13 they have listed I think is based on an actual documentary and not this set. Either way thank you for the help.
