I currently have OSMC running on a Raspberry PI 3.
I have an Amazon Prime account which I use on the IPad but was wondering if there was an easy way I could get my Prime account running through Kodi on the PI?
Any suggestions?
Sent from my iPhone Pro
Latest LibreELEC Milhouse builds support this since July 3rd.
Cheers all
Is there an add on I can use on the current build without having to burn an new image to SD?
It depends which build you are referring to. If you mean the OSMC test builds, then
you don't need to reinstall anything.
We hope to have support ready by the end of the week.
Sam
(2017-08-07, 13:23)Urbanbumpkin Wrote: [ -> ]I currently have OSMC running on a Raspberry PI 3.
Any suggestions?
Hi. To complete the picture with all the steps from scratch, I captured a brand new KODI 18 install + Amazon Prime Add-on on my blog here
https://robbesshed.blogspot.co.uk/2017/1...berry.html .
If you already have OSMC KODI installed, you can simply skip those bits.
