2017-08-07, 17:47
The background for this was buying a Sony XD9305 55" Android TV which I (stupidly) thought would be fast enough to fulfil most of my needs (streaming content from a NAS drive, mostly 1080 and 4K/HDR things). I quickly learned that the system on a chip inside the Sony is incredibly and infuriatingly slow.. so I bought an Nvidia shield recently which is, in comparison, wonderfully fast and rewarding! This new setup has some issues still, for example the receiver won't passthrough HDR content (I know i could connect directly to the TV from the shield, but then the TV doesn't pass many new sound formats back to the receiver *sigh*). So, all in all, this was the best compromise.
Yesterday I moved all of my gear around and then plugged everything back in together. Since then I have a problem which I cannot solve. Previously Kodi (running on the Shield) recognised that the receiver and TV were 4K, and hence - without any intervention from me - happily played any 4K videos at the right resolution. But now Kodi does not recognise that it can play 4K and instead downscales the video to 1080 . I have tried lots of tinkering with menu options, and testing different ports, checked the cables are compatible and rebooting everything in sequence, but nothing has changed this new situation. I did not change any configuration or update any software.
So... this is the situation in summary:
Setup:
- Nvidia shield running Kodi 17.3
- Shield connected to receiver (Yamaha RX-V675)
- Receiver connected to TV (Sony XD9305 55")
- Cables I am using are these: https://www.amazon.co.uk/gp/product/B002...UTF8&psc=1
Until yesterday, this is what happened:
- Shield set to 1080 output (but I could, if I wanted choose to output from the shield at 4K)
- In Kodi System > Resolution I had the option to output at 1080 or 4K (I used 1080 though)
- When a 4K file was played, Kodi would send it to the receiver at 4K
Now, this is what happens:
- Shield set to 1080 (I can still choose 4K in the shield settings, if I want to)
- In Kodi System > Resolution I do NOT have the option to output at 4K any more, only 1080
- When a 4K file is played Kodi downscales it to 1080
So it seems that Kodi doesn't realise that my receiver/display is 4K capable, even though the Shield itself does. Any ideas on what is going on? My next move - unless somebody has a suggestion - is to factory reset things, but, there must be an explanation surely?
Any suggestions/ideas about what is going on or sensible ways to try and get back to how things were before?
Joe
Setup:
Joe
