2017-08-08, 11:42
2017-08-09, 04:39
Ok
2017-08-09, 04:46
Goodevening member in good standing.
If you're referencing the 'restart Kodi' in the shutdown menu, then that would rely on your batch file for that trick. https://github.com/nuvious/kodirebootplugin/wiki
2017-08-09, 08:34
Hello
This is not the problem, when configuring KODI of August 8th (WIN64) in the extended monitor, turn off KODI (WIN64) and turn it on again, no longer works.
2017-08-09, 17:46
We need more information to be able to make suggestions, it also appears you are using an Alpha version of Kodi? The initial thought I have is, Displays (wiki) the pin #19 solution.
Check this out https://forum.kodi.tv/showthread.php?tid=42708
2017-08-10, 08:07
Ok, when configuring in the extended monitor, turn off KODI and turn it on again, no longer works.
KodiSetup-20170724-b609513d3e-master-x64.exe ---> ok
KodiSetup-20170809-67137d6348-master-x64.exe ---> bug
File Kodi.log:
*don't post logs directly in the post! use pastebin or similar* - dangelus
File Kodi.log:
2017-08-10, 09:17
Thanks for that
2017-08-10, 09:27
(2017-08-10, 08:07)tommy22 Wrote: [ -> ]Ok, when configuring in the extended monitor, turn off KODI and turn it on again, no longer works.
File Kodi.log:
@tommy22 we don't allow posting logs inline like this.
