Is there anyway in Estuary skin to remove the Inprogress and recently added movies and just show background. If possible , i wanted to select fanart slideshow with images on a particular folder.
This is the section in the code which defines the in-progress and recently added....
https://github.com/phil65/skin.estuary/b...ml#L51-L98
Recently Added has the ID "5200"...in progress has the ID "5100". Remove those section completely and you should be done.
Not tested, btw...So don't blame me if you break something. I would make a copy of the home.xml first before trying.
