Full Version: Screen rotate.
Hi All,
I have a convertible PC that has rotation function.
When I rotate the system, the screen is cracked.
I mean when the app is vertical mode, the text on menu is very strange.
Can you fix it?
I want to insert screenshot, But I am not able to find the method.
Thanks,
Minhyoung
Once you have set the path, the print screen on the keyboard should grab an image. It's quite possible that your o/s isn't handling the fonts well or the rotating function is doing something unexpected.
