I can't get videos to play full screen as you would expect. They appear as the playing in the top bar and instead that it opens up a playlist widget with the timer on the movie ticking over. And no other cute whatsoever I'm sure I've possibly switched something in settings. It's driving me around the bend.
Hi Connjam and welcome to the forums.
I have no idea about this and need a little more info.
What kind of videos are you trying to play (local media, networked media, streaming etc etc.)?
Which version of Kodi and which version of Rapier?
Could you please post some screenshots of these issues?
A debug log when the issue happens will be very helpful as well.
What is your default select action?
Settings > Media > Videos > Default Select Action.
Did you try this in other skins?
Hi Gade
I followed default actions. It was already on play. How can I send you the screenshots?
Uploading images is very similar to uploading the debug log.
Go to
https://imgbb.com/ and upload your images. Once they are uploaded, you will be given a link. Copy the link into a post here.
No account is required.
thanks for the reply guys. an uninstall and reinstall fixed the issue.
cheers
Hi Connjam.
Really glad you got it solved.
I'll mark this thread as solved.
