Full Version: script.module.t0mm0.common vs script.common.plugin.cache
just curious, what are these two plugin used for ? are they the same
I seem to get an error message for krypton for this plugin: script.module.t0mm0.common
however i also notice this other script.common.plugin.cache is installed .
are they the same?
what are the use of these plugin ?
They are two different addons.
t0mm0.common was an old set of functions to simplify addon coding. If the addon is using it then it will be auto installed along with the addon.
common.plugin.cache is a different addon and is used by scraper addons to cache web page requests, or even scraped results.
Gujal, thanks for the info Smile
much appreciated
